B2601: Removing Front End Loader without the Bucket attached?
   / B2601: Removing Front End Loader without the Bucket attached?
I’ll have to give that a try. Will the cement blocks be tall enough to mimic the dimensions of the loader and do you believe the loader will be stable enough on the cement blocks for storage purposes?
Mike
   / B2601: Removing Front End Loader without the Bucket attached? #22
I remove mine all the time with forks attached instead of the bucket. But removing with nothing would be a nightmare. For mine, it's not so much the ballast as it is having something on the front to get leverage to get the attaching brackets in the correct position.
   / B2601: Removing Front End Loader without the Bucket attached? #23
Adding
Mike
a little weight to keep the loader balanced is the reason for the block. The face of the coupler sits flat on the ground. The guys in the shop dismount LA525's without attachments all the time. I'm just not certain the loaders fitted to the B's are balanced similarly.
This might not work if you are among those that have to chase their loaders around to get them reattached. That really shouldn't be necessary.
   / B2601: Removing Front End Loader without the Bucket attached? #24
Please post your findings on the B-Series and the cement block. I would bet dollars to donuts that a cinder block won’t be enough weight. I’ve had several B’s, and with my B2620, a cinder block wound not have mattered. As mentioned, a blank SSQA plate would be best, and weight could be added to the SSQA plate until the right counterbalance is found.
Little Wonder High Performance Walk-Behind Leaf Vacuum (A55851)
Little Wonder High...
2014 Nissan Altima Sedan (A55853)
2014 Nissan Altima...
ATTENTION PLEASE READ (A56469)
ATTENTION PLEASE...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
pressure washer (A55973)
pressure washer...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
