Ford 1720 Rear axle seal
   / Ford 1720 Rear axle seal #1
bennommay
ford 1720
I have a1995 Ford 1720. On the rear wheel shaft I have a lot of fluid leaking out. I purchased Part #10, ball bearing seal, off the parts diagram below. I have removed the 4 bolts out of part#9 and have that cover free from the main body of the axle case where it spins on the shaft. I assumed the wheel shaft would then come out to be able to get to the seal I need to replace, but my assumption seems to be wrong.
Looking for any kind of help. Do I have to remove the main case, part #1, to replace the seal?
Thanks
20.
   / Ford 1720 Rear axle seal #2
You sure do. Then you disassemblethe axle assembly. See the nut (#20) on the inboard end of the axle shaft?
okay thanks. will have to wait until it's not the busy season to do this job
2018 JLG 1644 4x4 15,000lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
Lot of 2 2017 Stihl TS800-16 Concrete Saws (A48083)
Lot of 2 2017...
