I apparently don't understand oil weights
   / I apparently don't understand oil weights #32
Well, the upper outside temps on the charts do not make sense otherwise, unless they're for air cooled engines. All oils in water cooled engines run at around 212-230 F, being cooled by coolant at 190 F thermostat setting. VW TDIs, millions of them, run around with 5w30 in their crankcases. None have ever had an engine failure due to oil, according to VW.
   / I apparently don't understand oil weights #33
How would the oil know how warm it is outside once its running?
   / I apparently don't understand oil weights #34
If 5W30 is supposedly only good below 50F, why are they spec'ing it for all temperature ranges?
It isnt "only" good there,,,, they just reccomend the 5 for lower temps.
   / I apparently don't understand oil weights #35
Bout like 110 and 220 volts.
   / I apparently don't understand oil weights #36
Gotta love the guys on Bob,,,fussing over their 5K changes endlessly and telling everyone how they should really sample to get at the truth,,,, then a guy pulls it at 41K and its still 50% and he is going to hell for sure. More living proof we can "research" more and know less.
I have seen a lot, a lot of stuff stops equipment, wears it out over long times. Its really people more than machines. Changing the engine oil can be a good thing but its not the only thing. Rear lube and keeping the vent open pays off, doesnt have to be like a bat out of hell but a freshen with new fluid about 1/2 way thru doesnt hurt. I know people obsess about having an oil change,,, break out in a sweat at 3500 miles but can somehow drive a car till the fins on a rotor are thru and blows out a caliper,,,, but,,,, I cant understand it,,, I have the oil changed all the time. Try splainin how they noit directly related and skipping a change wont hurt but wearing the pads thru just cost 500$,,, but get those deer in the headlights look,,, well I wouldnt want to have to replace the engine so I change the oil every 3K and simply dont see how the wheel fell off,,,, after all I change the oil regular,,, I am a firm believer in that.
19.95 oil special and all of a sudden an expert in car maintenance.
   / I apparently don't understand oil weights #37
Most engine wear (about 90%) happens at cold starts.
Once an engine is running it depends on how it's being used. Severe duty can break oil down. Heat breaks oil down.
In a diesel, as longs it's in good shape, run 5w-40 synthetic and just drive it.
   / I apparently don't understand oil weights #38
^^^^^^ Too simple :)
   / I apparently don't understand oil weights #39
Exactly. That's why it's very important to get a small "x" # in a xw30 or xw40. A tad fuel credit for xw30 vs. xw40, but it's on the order of 1-2%. Main thing is to get a small first # which allows the oil pump to "grab" the oil instantaneously vs. sitting there "warming" the oil by not pumping it for a few seconds, with your bearings and upper valve train starving for pressure lubrication.
A synthetic will stand severe duty and heat a lot better because it has a higher boiling point for a given grade of oil.
   / I apparently don't understand oil weights #40
Read Bob for 5 minutes, pull 5K sample and become expert.
Versatile 260 (A53317)
8' Offroad Army Wagon (A56469)
8' Offroad Army...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A57880)
2005 INTERNATIONAL...
