JD 820 Antifreeze/Coolant Suggestions
   / JD 820 Antifreeze/Coolant Suggestions #1
coveredbridge
Gold Member
The Real Central PA
BX25D, JD 820
Time to flush the cooling system in my JD 820 3 cyl diesel (circa 1970). It has been a few years since the last flush and with all the developments in coolant types I'm not sure what AF/Coolant to use. The operators manual just says to use ethylene/glycol 55% and 45% water. It currently is filled with regular Prestone yellow/green Ethylene Glycol AF/Coolant. Any suggestions?
   / JD 820 Antifreeze/Coolant Suggestions #2
I'd be tempted to go to your local rad repair shop and see what they recommend. They would have a good idea what works in your local conditions. As long as they are trust worthy and will give recommendations for your benefit and not so that they can sell you a new rad in a few years. I have a friend that owns a rad shop and I get good advice from him.
   / JD 820 Antifreeze/Coolant Suggestions #3
I'd go with a reputable brand of ethylene glycol antifreeze. I usually stick with the Prestone brand and buy it undiluted. I can then dilute it myself. I flush the system with distilled water then use only distilled water to dilute the antifreeze.
   / JD 820 Antifreeze/Coolant Suggestions #4
I suggest utilizing an anti-freeze designed for a diesel engine. If mixing water with AF I agree that distilled water is preferred.
   / JD 820 Antifreeze/Coolant Suggestions #5
   / JD 820 Antifreeze/Coolant Suggestions #6
I like AF that meet the Cat EC-1 spec. It's called Extended Life Coolant (ELC) and a bunch of people make it.
Dang some people complain JD parts are high $$$$ but that Rotella AF is 2X as high as JD Cool-gard which is what I utilize in my diesel tractors. Cool-gard is advertised at being good for 6 yrs or 6000 hrs of use
   / JD 820 Antifreeze/Coolant Suggestions #7
I drain the coolant, check the recommended type, and radiator capacity, add 1/2 the capacity of fresh new undiluted coolant (no particular brand), stick the hose in the radiator, fill the radiator until full, and put the cap back on.
I do not flush unless rusty!
Works for me!
No issues for over 65 years, in a wide variety of automobiles & machines.
   / JD 820 Antifreeze/Coolant Suggestions #8
fried1765
Back in the 60's-late 80's when I was employed by a JD dealer it was unheard of for JD engines to get cavitation holes in engine cyl liners but today it a common occurrence. I think one needs to monitor engine coolant PH & be sure coolant more especially for diesel engines has the correct PH & additives.
Adding tap/faucet water to cooling system can be very detrimental & is prone to causing cavitation. You can put tap water in your vehicle's radiator but I don't want tap water in mine
When I was young only vaccine normally administered to a dog was for rabies prevention. Today dogs.cattle & horses for promotion of good health require multiple types vaccines & preventive measures including frequent applications of wormers.
   / JD 820 Antifreeze/Coolant Suggestions #9
I just picked the first one that showed. Tons of people make Cat EC-1 rated ELC coolant. I usually get mine from the local International dealer.
EC-1 ELC (or Ultra ELC) is the big favorite over on the various diesel boards I've been a member of over the years.
Good luck.
   / JD 820 Antifreeze/Coolant Suggestions #10
fried1765
Your souce of information for: "tap water is prone to causing cavitation" please ?
2014 Timpte Hopper Bottom (A56435)
2014 Timpte Hopper...
MASSEY FERGUSON 35 TRACTOR (A58374)
MASSEY FERGUSON 35...
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
CASE IH 7" X 7" FOLDING TOOLBAR (A58374)
CASE IH 7" X 7"...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
