JD 820 Antifreeze/Coolant Suggestions
   / JD 820 Antifreeze/Coolant Suggestions #1
coveredbridge
Gold Member
The Real Central PA
BX25D, JD 820
Time to flush the cooling system in my JD 820 3 cyl diesel (circa 1970). It has been a few years since the last flush and with all the developments in coolant types I'm not sure what AF/Coolant to use. The operators manual just says to use ethylene/glycol 55% and 45% water. It currently is filled with regular Prestone yellow/green Ethylene Glycol AF/Coolant. Any suggestions?
   / JD 820 Antifreeze/Coolant Suggestions #2
I'd be tempted to go to your local rad repair shop and see what they recommend. They would have a good idea what works in your local conditions. As long as they are trust worthy and will give recommendations for your benefit and not so that they can sell you a new rad in a few years. I have a friend that owns a rad shop and I get good advice from him.
   / JD 820 Antifreeze/Coolant Suggestions #3
I'd go with a reputable brand of ethylene glycol antifreeze. I usually stick with the Prestone brand and buy it undiluted. I can then dilute it myself. I flush the system with distilled water then use only distilled water to dilute the antifreeze.
   / JD 820 Antifreeze/Coolant Suggestions #4
I suggest utilizing an anti-freeze designed for a diesel engine. If mixing water with AF I agree that distilled water is preferred.
   / JD 820 Antifreeze/Coolant Suggestions #5
   / JD 820 Antifreeze/Coolant Suggestions #6
I like AF that meet the Cat EC-1 spec. It's called Extended Life Coolant (ELC) and a bunch of people make it.
Dang some people complain JD parts are high $$$$ but that Rotella AF is 2X as high as JD Cool-gard which is what I utilize in my diesel tractors. Cool-gard is advertised at being good for 6 yrs or 6000 hrs of use
   / JD 820 Antifreeze/Coolant Suggestions #7
I drain the coolant, check the recommended type, and radiator capacity, add 1/2 the capacity of fresh new undiluted coolant (no particular brand), stick the hose in the radiator, fill the radiator until full, and put the cap back on.
I do not flush unless rusty!
Works for me!
No issues for over 65 years, in a wide variety of automobiles & machines.
   / JD 820 Antifreeze/Coolant Suggestions #8
fried1765
Back in the 60's-late 80's when I was employed by a JD dealer it was unheard of for JD engines to get cavitation holes in engine cyl liners but today it a common occurrence. I think one needs to monitor engine coolant PH & be sure coolant more especially for diesel engines has the correct PH & additives.
Adding tap/faucet water to cooling system can be very detrimental & is prone to causing cavitation. You can put tap water in your vehicle's radiator but I don't want tap water in mine
When I was young only vaccine normally administered to a dog was for rabies prevention. Today dogs.cattle & horses for promotion of good health require multiple types vaccines & preventive measures including frequent applications of wormers.
   / JD 820 Antifreeze/Coolant Suggestions #9
I just picked the first one that showed. Tons of people make Cat EC-1 rated ELC coolant. I usually get mine from the local International dealer.
EC-1 ELC (or Ultra ELC) is the big favorite over on the various diesel boards I've been a member of over the years.
Good luck.
   / JD 820 Antifreeze/Coolant Suggestions #10
fried1765
Your souce of information for: "tap water is prone to causing cavitation" please ?
2025 Mini Excavator (A56857)
2025 Mini...
10 Paisano Trailer Dump Body, Year: 2021 Make: International Model: MV607 Vehicle Type: Truck (A56858)
10 Paisano Trailer...
JOHN DEERE LOADER LINKAGE (A52708)
JOHN DEERE LOADER...
LOLOT OF ROUND STOCK 2PC. (A58374)
LOLOT OF ROUND...
TABLES & WOODEN BENCH (A58374)
TABLES & WOODEN...
yellow ball Trailer (A56859)
yellow ball...
