Wits and Bits of Nothingness, Volume Four
   / Wits and Bits of Nothingness, Volume Four #1
drssg
Elite Member
Ohio
Kubota M5700, JD 1025R
I received a package of tractor parts today, and the box contained a fair amount of bubble wrap, so I decided to pop a few bubbles before throwing it out.
As it turns out, this bubble wrap has some sort of newer and more elastic design that makes it resistant to popping! I squeeze a bubble, and then it quietly returns to its original state.
I tell you, this country is going down the tubes! 🤪
   / Wits and Bits of Nothingness, Volume Four #2
I used to work with a fellow who was approaching village idiot status. If we had packaging come in with bubble wrap I would hide it under the other garbage. He would inevitably find it and you could hear him out in the other shop popping it while getting paid $40 per hour. I'm not saying that I haven't popped a few bubbles but there is a good chance he took it home and played with it.
   / Wits and Bits of Nothingness, Volume Four #3
Sounds like my Beagle... If you have any piece of paper on you, she will get it and shred it; she can't be stopped...
   / Wits and Bits of Nothingness, Volume Four #5
Not many use the bubble wrap any more. It's too heavy and too expensive to stock--Takes up too much room. Most use the "air bags". High volume shippers even have machines so the bags can made on the spot as needed. Those really make a loud pop! :D
   / Wits and Bits of Nothingness, Volume Four #7
Note to self: Air tools do not work wirthout air hoses connected.
   / Wits and Bits of Nothingness, Volume Four #8
Note to self: Water in metal saucepan goes on top of stove, NOT in microwave.
Many years ago, a co-worker tried to warm up his Wendy's cheeseburger in the microwave. It didn't occur to him that the wrapping contained foil.
The running joke afterwards for anything that was not worth keeping was, "Wrap in in foil and put it in the microwave."
UNUSED FUTURE FT13C EXCAVATOR (A57192)
UNUSED FUTURE...
2019 Caterpillar 308CR (A53317)
2019 Caterpillar...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
HOMELITE 2700 PSI 2.3 GPM PRESSURE WASHER (A57192)
HOMELITE 2700 PSI...
UNUSED WOLVERINE CCT-11-148V CONCRETE CHUTER (A57193)
UNUSED WOLVERINE...
