Tree Claims Hunter
   / Tree Claims Hunter #2
Tragic. My condolences.
Falling is a top 10 cause of unintentional injury deaths over the age of 15, and #1 cause over age 65.
...but I beg to differ with the sheriff. And so do the results.
   / Tree Claims Hunter #3
That's a shame. Sometimes it's the tree that is the killer. I lost a friend when he was crushed by a tree.
Environmentalist dies
   / Tree Claims Hunter #4
Unfortunently the articles do not mention safety harnesses which should always be worn . I spend on average 20 days a yr hunting from a tree. Until about 20 yrs ago i never wore one either. and came close to falling several times while dozing off . A full body harness is a must especially for us older guys.
   / Tree Claims Hunter #5
I have to go up a 20 foot tree stand Friday to cut the lock off, which somebody put on to keep me from removing it. They are supposed to have their name on it, and I believe they are required to be removed after deer season. Luckily it's just a standard Master padlock so should come off easily.
I don't like heights and especially don't like climbing up tree stands, then removing the supports which hold them to trees. Hopefully DI won't start the new year posting about me.
   / Tree Claims Hunter #6
Coby,did you find stats for irate property owners killed while using both hands on bolt cutters 20 feet above ground? Killed as result of falling,not from being shot by blind owners?:eek:
   / Tree Claims Hunter #7
No bolt cutters involved. Those little Master locks succumb easily to a good cold chisel and 2 lb hammer. You don't need to cut it; just break the shackle out of the lock.
   / Tree Claims Hunter #8
Okie Dokie Coby,can you find stats comparing hammer and chisel with bolt cutters causing property owners to fall? Let's also include injuries from flying metal chips.:laughing:
   / Tree Claims Hunter #9
We have a hunter next door whose chair is on a dead Ash, which is starting to lean.
I pointed this out to him and he just shrugged.
Guess he wants to buy a new chair soon, luckily it did not fall on him while he was in it.
Have found 2 decomposed deer carcasses not too far from that area....maybe he needs to use traps instead of Bow :2cents:
   / Tree Claims Hunter #10
Shouldn't the title read "Gravity Claims Hunter" ??
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
BED FROM 2024 FORD F250 SUPER DUTY (A57880)
BED FROM 2024 FORD...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
Adams 16T Tender Body (A55315)
Adams 16T Tender...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
