IF you own a freezer......
   / IF you own a freezer...... #21
We have several motion sensor driveway alerts and several trail cams that we use Lithium batteries in. Makes a big difference in sub-zero temps. I just wish Amazon would start shipping Lithiums again.
Presumably they stopped because so many were using them to make crystal meth?
   / IF you own a freezer...... #22
I thought it was because of the FedEx plane carrying millions of Lithium batteries that crashed and burned (or, was that burned and crashed)? No rhyme nor reason to what they will ship or not ship.
   / IF you own a freezer...... #23
I'll be damned Jstpssng . . . I looked it up . . . I guess it was the inventors of it (nazti) that originally invented such.
   / IF you own a freezer...... #24
Let the Meth Heads kill themselves with that poison...that leaves more Pie for me!
   / IF you own a freezer...... #25
They're all going to Oregon.
   / IF you own a freezer...... #26
   / IF you own a freezer...... #27
   / IF you own a freezer...... #28
Get Hobo Shoestring to bring you some Lithiums the next time he catches out to Alaska.
   / IF you own a freezer...... #29
They are working on getting a railroad built from Alaska thru Canada to the Lower 48. Both Hobo Shoestring and I will probably be long dead before that happens. Great idea though.
   / IF you own a freezer...... #30
I have been given 3 side by side refrigerator /freezers in the last two months just to get them out of peoples way due to them not working.
Having been in the business for many years, I repaired these three side by sides for cheap money. All they needed was the overload /relay kit to get them up and running.
However, last week I was given a newer side by side. Again, to get it out of someone's way.
Got it home to find out it had a bad /burnt circuit board on the back .
It will cost me $150.00 to replace the board.
It seems the manufacture has figured out we are able to repaid the older types, and have now installed circuit boards
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
20 Gallon Air Compressor (A50860)
20 Gallon Air...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
Iron Platform for Forklift (A50860)
Iron Platform for...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
