What have you done to your Branson today?
   / What have you done to your Branson today? #681
Got our first light dusting of snow yesterday and today.
Time to get the box blade back on the 3 pt and get it leveled out and ready. Also time to put the Edge Tamers on the FEL bucket.
   / What have you done to your Branson today? #682
WOW, I like it Aquamoose. B.
   / What have you done to your Branson today? #683
I've been using my tractor and trailer to move branches over to another location but yesterday we had a little bit of rain, so I decided to tackle an easy and quick project.
I built an extension for the 3 pt lever. It was a bit low and kind of tricky to go adjust the height from the outside of the tractor when hooking an implement.
It's about 5" longer than stock but keep in mind that I already remove a 2" factory spacer under the seat. Yes I'm on the short side and the tractor was built for you tall Americans. :laughing: While I could reach the pedals with the seat all the way forward and with the spacer in place, it wasn't comfortable for me.
Anyway, I didn't bother extending the Draft control lever as I don't really use it anymore as I sold the turn over plow a month or so ago. The extension has about 15 degree tilt forward and about 10 degree to the right side. It does clear the Gear shifter lever when engaged in 4rd gear as shown in picture 5.
Some pictures:
IMG_20201114_110005.jpgIMG_20201114_110018.jpg IMG_20201114_110236.jpgIMG_20201114_111220.jpg IMG_20201114_111244.jpgIMG_20201114_111259.jpg
   / What have you done to your Branson today? #684
Very nice ptsg! That looks like a factory extension!
   / What have you done to your Branson today? #686
That looks well thought out and made like all your fab work.
One of those has been on my list of stuff to make since I got my Branson.
   / What have you done to your Branson today? #687
**** Pedro... seriously nice work! I wish I could fab like that.
   / What have you done to your Branson today? #688
Thanks guys!
If this is something you could use, I can draw it up on CAD software and make a drawing of it.
I'm thinking that for H models, I can tilt it to 20 or 25 degrees forward. It will give more room on the remote levers with the 3 PT lever all the way back.
   / What have you done to your Branson today? #689
Ptsg inspired me to do some fab work! Not nearly as nice as his work but functional.
I wanted a stop for my 3pt control. Being a cab the boot keeps me from using the factory one. There is a brace for the side panel that is in the right spot to fab from but I wanted to keep the original part.
I used what I had to fab with so a lot of making do but I think it turned out ok.
First step was to duplicate that part.
Next was to fab a bracket to hold the stop and weld it to the new part.
It fit perfectly and I think it will work great!
FB4677B4-FC7C-43AF-88F1-9D4CE6D24C48.jpeg 97A00B26-BBB9-4416-A254-B323CE88938A.jpeg
Now I just need to clean and paint it. :laughing:
   / What have you done to your Branson today? #690
Great work K5! Looks awesome.
That's actually pretty dang similar to what I had in mind. Although, mine doesn't have the sound deadening material, so it would make it slightly easier to build.
So far, I only had the need for a stop one time, I don't think I'll one anytime soon.
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
2012 ADDCO S/A Towable Arrow Board (A55973)
2012 ADDCO S/A...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
