sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,765
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I need to remove the tie rod end on a new-to-me M7040 Kubota so I can replace the "knuckle" joint on the tie rod shaft. I do have a pickle fork that would remove the tapered end but the fork is too small. Kubota shows some exotic spreader thing in the service manual but don't have one of those. So how to remove the tapered tie rod end?
I could loosen the slotted nut and whack the threaded end with a hammer. I could use an impact hammer and hit the sides of the tie rod end in hopes of loosening it. Maybe use a puller to pop it out? If it helps, the torque of the rod end slotted nut is 60 ft lbs.
Any help on this? I don't have enough experience and don't want to screw it up.
