BX 24 will not go up a hill with a loaded bucket
   / BX 24 will not go up a hill with a loaded bucket #1
David Glaser
I have an interesting problem.
I have a 2006 BX 24 with about 500 hours of operation
The tractor will not go up an incline with a full bucket of dirt. However, I can back up the same incline with a full bucket (I have to put the tractor in 4wd mode to do this).
The hydraulic fluid is fine
Any ideas of what is wrong and what the repair costs might be?
-David
   / BX 24 will not go up a hill with a loaded bucket #2
What is the maintenance record on the hydraulic system. Fluid and filter change hours?
   / BX 24 will not go up a hill with a loaded bucket #3
Are you in low range? How are you using the forward-reverse pedal?
Brice
   / BX 24 will not go up a hill with a loaded bucket #4
Not enough information!
Wheel slip? Go pedal pressed to the floor? BAD!
Engine RPM ? Sounds? Performance on flat ground?
Make it into a story, Or else it's gonna cost you $47,987 to get it fixed. Cash in advance!
   / BX 24 will not go up a hill with a loaded bucket #5
.....................:D
   / BX 24 will not go up a hill with a loaded bucket #6
Have you tried in 4WD? Low gear? In 2WD your wheels are probably just spinning.
   / BX 24 will not go up a hill with a loaded bucket #7
more counterweight on the back is what you need.
   / BX 24 will not go up a hill with a loaded bucket #8
you have 4wd... use it
you have to be in low range
throttle way above idle
bucket off the ground
pedal pushed down 100%
Still not moving???
   / BX 24 will not go up a hill with a loaded bucket #9
-David
No where near enough information to draw any conclusions. You say it will not go up the hill. WHY won't it go up the hill? Are the wheels spinning inside the tires? (bead slip) Are you in 2 WD and the rear tires are slipping on the road surface? Are you in HI range and the relief valve of the hydro is opening?
Give us more information, write a book.
   / BX 24 will not go up a hill with a loaded bucket #10
-David
I am not mechanical at all but a friend had this exact same issue on his Kubota TLB. TBN won’t let him log on and he asked I relay his fix. There is a fuel bi-pass on the injector pump. A round knob. Turn that all the way in. His ran like new after he did that.
2017 Jeep Patriot 4x4 SUV (A55853)
2017 Jeep Patriot...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
2015 Toyota Prius (A56859)
2015 Toyota Prius...
2017 Ford E-450 Super Duty Shuttle Bus (A55852)
2017 Ford E-450...
JLG 1255 Telehandler (A55315)
JLG 1255...
