Buying Advice Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac)
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #61
Found a nice 2016 with high flow, traction control and power bobtach in Wisconsin at a Bobcat dealer. 39K or $41,500 with a Bobcat bed mount material spreader
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #62
If I had to do it all over again. I would probably go for some small European articulated tractor with a hitch and pto on both ends. HOLDER for one, although NONE of these is well supported over here. And then still get a small wheel loader for loading and that kind of stuff.
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #63
Are there any tractors that have the cylinder standard on the quick-attach. And are there any tractors that can run high-flow attachment (33 gpm with high-flow lines)?
Power SSQA is an option on the Kubota Grand Ls. I think it was almost a $2k option if I remember choking & skipping it when I bought my L4060. The cylinder alone runs $800+ at Messicks last I looked. Way cheaper to DIY it with a standard cylinder & making your own brackets.
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #64
I like the 5610 with the 3 point.
This is an eight foot wide box blade on the 3 point leveling some hauled in dirt:
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #65
And more info for future info seekers on the push/pull capabilities of a Toolcat
On the front a six foot wide box blade on a three point adapter that is on a Tilt-Tach:
Bulldozer mode pushing dirt:
And on the three point adapter, no Tilt-Tach, pulling and leveling dirt:
@Xfaxman Adding another update to this thread. A few months after starting this thread in 2019, I bought a ~1997 Deere 755, mostly for mowing. I sold that at the end of the summer and then bought a Kubota L4330 GST. Much of my 14 acres is very uneven and I feel really tippy in all but the few acres around the house. Just before buying the Kubota I rented a Bobcat T650, which was a beast around the property and very stable. I also rented the rotary mower and tiller, which chewed through 3-foot grass and turned two acres without any issues.
After the Kubota sels, I've decided on a ToolCat. Maybe a 5600, but I will likely hold out for a 5610 F-series. For my needs, I think the ToolCat will work just fine.
Question: How much better is the G-series over the F-series? Are there any G-series years to stay away from? Any major improvements in a specific year of the G?
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #67
@Xfaxman Adding another update to this thread. --------------------------------------------
The reason I traded our F Series in on a G Series in 2017 was to get Traction Control.
I am not aware of any changes, but have not been looking at the newer ones.
A good feature of the Toolcats is no Regen that I read so many complaints about.
@Xfaxman How does the G-series handle Tier 4 without regen?
Have you noticed any quality/reliability differences between the F and G series?
Do you notice the additional 5 horsepower of the G?
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #69
The new Bobcat engine, Here is info from their Website:
When Tier 4 emissions standards required every equipment manufacturer to make equipment changes, Bobcat designed a non-DPF Tier 4 solution that also delivers new features and provides more performance to customers. It reduces downtime that occurs with DPF regeneration and long-term DPF maintenance costs.
No.
No, never had a lack of power on either one for what I was doing.
Just came in from working on relocating part of our driveway:
Moved the box blade to the front so I could see what it is doing:
@Xfaxman How would you compare your V417 to your 5610?
Forward 10,000lb Two-Post Electric Auto Lift (A55852)
Forward 10,000lb...
2025 Mower King SSRC (A56469)
2025 Mower King...
2013 John Deere 5101E (A53317)
2013 John Deere...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
2026 Kearney 102" x 40' Gooseneck (A53317)
2026 Kearney 102"...
2017 Kubota L4701 (A53317)
2017 Kubota L4701...
