What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,201
View attachment 654653View attachment 654654View attachment 654655View attachment 654656View attachment 654657
This is this week got ground around old barn cut down to let water go around not through it. Got all the old manure dragged out of building about 8 inch in each section! This building when we started had half the roof flapping in wind every time it rained and all the siding was rotted 16 inches up the sides and half the sidind supports were broken. Now I need to put some of the bigger rocks we dug up around it along the walls and go get some gravel to fill inside and level floors then equipment and tractors will have a dry place to sleep! Its 24' x 44' and center is 11' thinking of putting a rack in back of middle section to place implements on that dont get used all the time put them up with forks from tractor!
Great job! You are going to have some monsters if those boys grow into those feet! I enjoy watching families working together.
   / What did you do on or to your LS Tractor today? #1,202
I have one section of the storage racks like home depot uses its about 10ft tall and has multiple shelves I'm thinking of putting it on the back wall center and maybe using it for frontend loader buckets and forks they could be set there after unlocking quick attach and then would not need to have them take up so much space! And yes I will be putting shelves on all the side walls for all those things we use daily and need to leave sitting out but not end up leaving on the ground. Will be very nice once I get power out there and can have shade to do maintenance!
   / What did you do on or to your LS Tractor today? #1,203
Wife spent most of afternoon spreading the majority of 45 tons of 3/4 minus around the shop-after I unloaded my new (to me, but hardly used) Muratori MZ6 185 tiller and adjusting it to fit my Farmhand quick hitch-tiller is a beast-look forward to breaking ground on some food plots later in the spring.
   / What did you do on or to your LS Tractor today? #1,204
You guys did great! Looks really nice! Your help did great.
   / What did you do on or to your LS Tractor today? #1,205
Used the grapple and flail mower cleaning up all day Saturday. Lifting and moving in the front and cutting and mulching in the back.
   / What did you do on or to your LS Tractor today? #1,206
Did install of a bunch of split rail fencing. The LS and PHD were quite effective at digging the holes. I got a lot more done than I was planning.
   / What did you do on or to your LS Tractor today? #1,207
Outrigger cleats.
OK, so you did a T, I did an L, somebody else did twin Is, I think I saw one C layout (or was it a U?) .... we'll have the whole alphabet before long.
   / What did you do on or to your LS Tractor today? #1,210
I think there is. The only ones available I have heard of was a set available from Kioti dealers that fit, for almost $200.
I made myself a set since these backhoes are next to useless without them. A guy on TBN asked if I would make him a set and mail them, so there is a market.
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2013 International WorkStar 7400 Altec D3060ATR Insulated Digger Derrick Truck (A55973)
2013 International...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
33' x 25' Double Garage Steel Barn (New/Unused) (A59225)
33' x 25' Double...
