MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,680
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I don't know what you mean by "position control". I have TNT, use it all the time when working the road.
Units I'm looking at range in weight: 635, 700, 790 and 825 lbs. The first two are 7' and 8' non-scarifiers, the latter two are 7' and 8' with scarifiers.
The parts of the road I normally work on are what I call the "mudholes". There are five on them on my road; there used to be a sixth, but heavy reconturing and a load each of #4 and #67 gravel fixed that.This is where the road that is flat, doesn't have enough rock - or the right kind of rock. When it gets wet, people drive on it and make a track. The next person drives right in the same track. Before you know it, it's a bathtub, then a pothole.
I've been slowly improving the road, specifically the drainage. My EA grader blade with it's ability to really reach out on the side of the road where I can't drive, has been a huge help.
Thanks,
Position control is your 3pt hitch lever.
For your application, I recommend going with the 7 footer with the scarifiers.
Just my :2cents:
