Anyone have a JD 4600 / 4700 with creeper gear?
   / Anyone have a JD 4600 / 4700 with creeper gear? #11
Different tractor, 6000 series. But I kick myself that I didn't add creeper gears when I replaced the transmission a while back. Hydrostat is one thing, but as for gears, you can never have enough of them.
   / Anyone have a JD 4600 / 4700 with creeper gear? #12
Here is a schematic of the operation of the creeper gear.. so if you can figure out if it is in the tranny, and how to move it with your lever, you may have success..
   / Anyone have a JD 4600 / 4700 with creeper gear? #13
Maybe this will help. This is the transmission case, left side. D = Differential Lock. G = Gear shift. R = Range shift. C = Creeper shift
   / Anyone have a JD 4600 / 4700 with creeper gear? #14
Can add to Zeb's post, the creeper shift mechanism..
   / Anyone have a JD 4600 / 4700 with creeper gear? #15
And the creeper control shifter . Hoping the OP is getting some help from this. Maybe we'll hear back.
Great!!! Thanks guys. I'll compare to my trans tomorrow and report back
   / Anyone have a JD 4600 / 4700 with creeper gear? #17
Interesting. While I have the HST version of the 4600, I would be interested in what the Creeper gear would do for you?
Thanks. It doesnt appear the creeper is in there.
Tilling mainly, and just to have it
   / Anyone have a JD 4600 / 4700 with creeper gear? #19
Do you have just the shaft coming out of the transmission case? Or also the linkage and lever?
2015 Caterpillar 257D (A53317)
2015 Caterpillar...
2022 Caterpillar PR121 (A53317)
2022 Caterpillar...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
Mailbox (A55853)
Mailbox (A55853)
3pt 5' Box Blade (A56469)
3pt 5' Box Blade...
2003 International 9200I (A56469)
2003 International...
