Is it time to reorganize?
Should we combine some forums?
  • Yes, too many sections
    Votes: 13 20.0%
  • No, sections are good
    Votes: 52 80.0%
  • Total voters
    65
   / Is it time to reorganize? #171
Apple. Good for pies, sauces, fritters and turnovers.
Apple fritters :licking:
How does everyone cook them? I always like Gravenstein apples the best. I batter them, and fry in a light amount of oil. Then brown sugar and honey topping. :licking:
   / Is it time to reorganize? #173
Yep, it's been a very stable platform.
Just like buying a new vehicle or tractor. There are things you don't like. If you change them quickly they get changed. If you delay, you convert and they don't get changed.
If the format here is changed we don't have choice number 1. So we'll conform. Those that cannot will move on. One poster on this thread has already said his goodbyes. :)
It like, need a FEL, but they cost too much and cause in time front suspension issues or just do it the with a pond scoop that takes a little longer. Still gets er' done. :laughing:
   / Is it time to reorganize? #175
The terminology might be inaccurate but it's a very valid concern. A friend sees major damage in front axles of small loader tractors all the time. Just because you can do something, doesn't mean you aren't destroying your equipment.
   / Is it time to reorganize? #176
Avoiding owning an FEL because of front axle fears should be reserved for those unwilling to learn how to properly operate a tractor. After paying sufficient tuition, some actually learn. Part of that process could involve understanding what a suspension actually is.
   / Is it time to reorganize? #177
Not all front axles are created equal. Only time will really reveal the truth.
Look at the history of tractors. They are designed all wrong to carry weight up front. Any company that built commercial forklifts, using a tractor, stuck them on the back for very good reasons.
   / Is it time to reorganize? #179
Calling a 5R a compact is stretching conventional wisdom a bit. But if you accept that, front suspension has been offered on large Ag tractors for many years.
   / Is it time to reorganize? #180
But avoiding having a FEL on the tractor, would be bad for your business. You wouldn't have to change so many front wheel seals, bearings and bushings so often... :)
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
PSI 8 Cylinder Power Unit (A57149)
PSI 8 Cylinder...
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2293 (A58376)
2293 (A58376)
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
