Kioti CK-35 -11+ years and still running strong!
   / Kioti CK-35 -11+ years and still running strong! #1
Dave from GA & KY
Live in GA farm is in KY
Kubota M7060 Kioti CK35
On 5-22-2008 I posted a thread here titled "CK-35 Arrived!". Members here were very helpful with advise and information which ultimately led to my buying this tractor. I sort of abandoned this site for quite a while as I've only had 1 post in the last 10 years. I thought folks here might enjoy hearing about my experiences with 11 1/2 years with this little tractor.
Quick history - I bought a Kioti CK-35 tractor with a KL-130 loader and a tooth bar on the bucket back in May of 2008. I have a Bush Hog squealer SQ600 5' rotary cutter and a Bush Hog SQ600 5' rollover box blade I bought about the same time. Have also acquired a 5 gang spring-tooth plow, 10' Farm King drag harrow, Bush Hog post hole digger, an old Massey-Ferguson 7' adjustable disk (cuts like no other), a 400 lb. spreader, a 2-row John Deere planter, and a 6' Top Choice finish mower. I have a 300 acre farm in Kentucky with about 100 acres clear and the rest wooded. We use the farm for hunting and recreation, I leave the real farming to a local that makes hay off my tillable ground, but, even so, this leaves plenty of work for this little Kioti tractor.
Problems I've had with it over the years...
FEL joystick wore out & had to rebuild it. Kioti had a kit that beefed up the original equipment nylon "balls" with brass or stainless, can't remember exactly. Ordered the kit and put it on myself, took about an hour as I remember. That was about 6-7 years ago and haven't had any problems with it since. Kit was about $100 I think, I was a little irritated they didn't give it to me since this was a known and pretty common failure, but, it wasn't terribly expensive and worked great.
My battery no longer charges from the alternator, not sure why, alternator is putting out juice. But, have had mice chew wires and my gas gauge no longer works, so may have something to do with it. I just put a battery charger on it once in a while and top it off, no worries.
I keep losing the stinkin' pins and pieces off the check links on the 3 point hitch. Seems these links could be better designed because when running through heavy brush the little snap pins get pulled out and everything starts falling apart. I have started wrapping all the joints/pins/clips with duct tape before I go into heavy brush. It works, just cut the duct tape off when you're done.
That's about it for problems. In 11 years, I'd say that's not bad!
I have worked this little tractor hard, very hard. Everything from grading & digging to plowing & planting to Bush hogging 5-years over-grown fields to mowing the yard to logging, and it has never let me down. With this much land there is always something to clear, cut-up, clean-up, mow or plow. It'll work hard all day on 5 gallons of diesel, it'll go places bigger tractors won't, It's heavy enough to be stable, it is comfortable to operate, and after all these years, it still looks pretty much like new! I really couldn't ask for more and would buy another Kioti in a heartbeat.
Dave
   / Kioti CK-35 -11+ years and still running strong! #2
Hours on tractor?
   / Kioti CK-35 -11+ years and still running strong! #3
Excellent to hear dave.
I have read where people have replaced the hairpins on the check links with cotter pins.
Good luck with the next 11 years.
   / Kioti CK-35 -11+ years and still running strong! #5
Only about 680 hours on it.
Chump change for hours. I have a pair of Kubota M9000's, I biught a year apart.both hydraulic shuttle. One is a cab with 2 speed pto and creep gears and both have loaders. The cab tractor is a 2004, it has 2100 hours on the meter the other is an open station just the standard M9000. It was bought a year before in 2003, It just turned 3600 hours. I farm with both if them and have since new and other than replacing one set if tires in the open station, I've done nothing but routine maintenance, engine oil, hydraulic oil and required filters, nothing mechanical has ever failed.
I will say the open station is going to my dealer this winter, time to run the overhead at 3600 hours. I fully expect them both to go well in the excess of 5,000 hours with nothing major failing. Hope your Kioti tractor lasts that long and stays trouble free.
I do an oil analysis every second change (engine and transmission) and nothing out if the ordinary ever shows up on the report.
I'm very satisified with both my Kubota's.
   / Kioti CK-35 -11+ years and still running strong! #6
Around here folks put old Fords and Masseys in their will. I hope Kiotis are as durable. My 2006 DK45s has been so far.
My finish mower has the "missing pin" problem too and it's costly to replace a missing caster and spacers. So I replaced those snap pins with bolts and nylock nuts.
   / Kioti CK-35 -11+ years and still running strong! #7
Those two Kubotas have chump change for hours too.
Probably 700hrs on the little ck is similar to a couple of thousand on the M9000.
My 2013 DK90 has a couple of thousand hours on it. It runs like new, as it should with only a couple of thousand hours.
2000 hours is only 250 eight hour days..
I will be very disappointed if my Kioti cant go 5000 hours without any trouble. It should go 8000 without major maintenance (other than possibly clutch), imo.
And again, good luck in the next 11 years!
   / Kioti CK-35 -11+ years and still running strong! #8
I bought a 08 ck35 hst and it has 1350 hrs. on it. The only thing I had to replace is the oil cooler. Developed a small leak. So far been a reliable unit.
   / Kioti CK-35 -11+ years and still running strong! #9
My 2001 DK 35 has 2205 hours.
Its been great.
Still working like new.
   / Kioti CK-35 -11+ years and still running strong! #10
I have a 1956 International 350 utility with 7000 hours and still going strong.. My brother has a 1982 Ford 7710 with 10,000 hours still running strong..:D
White Metal Roof Panels (A55758)
White Metal Roof...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2021 CATERPILLAR 349 EXCAVATOR (A52707)
2021 CATERPILLAR...
EZ-GO Golf Cart (A56469)
EZ-GO Golf Cart...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
