OP
Little General
- Joined
- Apr 7, 2019
- Messages
- 76
- Location
- Mi. Pleasant , N/C/
- Tractor
- Kubota M7060 w cab Kubota x1100c Kubota KX008 John Deere 4400 , JD TLB110
I will check the tire placement this weekend. I grew up dealing with filled tires and draining them and fixing a tube and then refilling them...mine are all air. I did let the pressure down to 12 psi, they were at 25 and I scooped up a full bucket of dirt and the front bulged pretty good ,so I left the pressure alone in the front. I removed the FEL, took all of 2 min. I mowed a couple acres in the rain this afternoon and had to go slow in the thick stuff as not to miss grass. Im using a Landpride 84" finish mower in 5th gear low range. In case you guys didnt read the buying section, I had been waiting on a L6060 I ordered in May and bought this M7060 with the FEL for the same price as a L6060 with no FEL.
