   / Harbor Freight Tools that don't suck #11,212
Just remove the side cover. That's not tampering.
You had to do that to install your bar and chain when you got it.
That clip was fine, whatever was broken was in the motor/drive assembly, which would have taken further disassembly.
Moot point, I brought it back to the store and they told me if I purchased the extended warranty they'd swap it out for a new one. First time I've ever heard of a place that will let you buy the extended warranty after the product broke! So for ~$22 I got a replacement and the extended warranty on the replacement. :thumbsup:
As someone else noted, I'm not sure how they make any money, but you can't beat the customer service.
   / Harbor Freight Tools that don't suck #11,213
I've destroyed a few of those with little to no effort. Meanwhile, I've had a regular Unibit (whoever made them) for many, many years that's still going strong. And they're always on sale. One of those perpetual coupon items we discussed a few pages back.
Those Unibit step drills work great for me. I drill holes in thin stock or odd things and have yet to wear one out. Last use was to put a vent of tapered diameter in my plastic gas can. I just kept step drilling until it fit tight. Saved time and jerking around looking for the next size bit. HF also sells a reamer ($5 ?) that is perfect for some uses.
   / Harbor Freight Tools that don't suck #11,214
They work well for plastic, wood, and mild steel. They DO NOT work on stainless steel.
   / Harbor Freight Tools that don't suck #11,215
I've been using the same 2 pc step drill set for years. I normally use the larger of the 2, and have used it to drill holes in mild steel back cans for electrical conduit couplers when piping conduits and flex into alarm panel back cans. I'm still on my first set of 2, which I bought on coupon sale, for less than $20. The 3 pc set goes on sale more often, but I wanted the 2 pc set for a larger spread in hole diameters with less bits to carry around.
Still satisfied with mine.
   / Harbor Freight Tools that don't suck #11,216
I don't remember what all I've used them on but the points are broken off two of the three piece set and at least one has one step size dulled to where it won't cut anything. Both of the two larger ones in the two piece set also have at least one step dulled. I don't know of a way to sharpen them either.
   / Harbor Freight Tools that don't suck #11,217
Used my HF step drill set to install a Piranha bar on a buddy's Kioti loader bucket a couple of months ago. Went right through the approx 1/4" steel plate with no hesitation. We were impressed.
   / Harbor Freight Tools that don't suck #11,218
Here's what my bit looks like after use on plastic pots.
Bruce
   / Harbor Freight Tools that don't suck #11,219
I did the same on my bucket for the PTB.
   / Harbor Freight Tools that don't suck #11,220
THREE POINT ATTACHMENT (A58214)
THREE POINT...
202479 (A54757)
202479 (A54757)
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
2002 POLAR TANK (A58214)
2002 POLAR TANK...
2006 Mac 35ft Tri-Axle Dump Trailer (A56858)
2006 Mac 35ft...
