Freep
Greetings, TBN!
I need a drag harrow* for what seems to be a relatively uncommon purpose. I've searched and read to see if I can find just the right bit of equipment for my needs, to no avail - time to inquire! It does seem like there is a whole lot of experience in drag harrowing here, so I'll wager someone knows exactly how to tackle this job.
Context/Problem: I have about four acres of mowed land that is not flat, but sort of wavy, with little hills and natural valleys. These features are fine and I'd like to keep them: I do not intend to flatten my land. There are larger holes that I am slowly filling with organic stuff and I am content with this process. The problem is that the whole property is very uneven, with little holes (& etc) that make it hard to walk without some caution. The previous owners had horses that created uneven textures in the often-moist Pacific Northwest soil. There is also an entire civilization of moles or gophers that live on the property. There are at least 100 little mounds in plain view from my upstairs window.
Goal: I'd like to just even it all out so that I can walk and my kids can run without risking a twisted ankle at every step. I'd like to smooth the mounds into the soil and fill the holes without removing all the grass and/or topsoil. I don't mind if it's torn up and looks rough for a while; I use a flail mower and any debris will be turned into mulch on the next mow. I don't mind if it takes a while either: I know I'll have to do it repeatedly unless I murder all the moles (not a fight I plan to pick).
Solutions: Because I don't want to remove all the grass or topsoil, the vast majority of implements available are eliminated. I think some of the commercial drag harrows could be useful if turned over on their non-aggressive side, but then I would have purchased a fairly expensive harrow only for a secondary purpose. I could be convinced to but a 5' wide commercial drag if its aggressive side would be useful for road-smoothing and it it could be dragged with a two-wheeled tractor as well. I think what I need is a chain link drag with weights affixed to it (every square foot or so), such that it will flow into the little valleys without just riding over them as would a rigid frame. But I have never used a drag before; my knowledge entirely comes from reading these forums. I'm probably overlooking something important.
Other ideas:
I have a 35hp 4WD tractor and a two-wheel tractor (BCS 853). It would be great if I could use both. I mow with the front of the BCS, and could drag a small harrow behind it, especially up close to trees and such so I don't compact soil.
It occurred to me that I could construct a harrow, attach it to my ratchet rake, float the loader, and drag it backwards such that the rake broke up big pieces and the harrow then smoothed them all out. That's a lot of backing up, but it seems doable.
*Or, maybe I don't... feel free to tell me about some different contraption I need instead. I'm not wed to a drag - it just seems like a fairly cheap and easy solution. If there's something else that will make it all exponentially easier I'm happy to consider that as well.
Other ideas:
