Buying Advice Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac)
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #21
Sounds like we have to test drive!!!!!!!!!
Would love to! :thumbsup:
I've been watching the toolcat and telehandler posts for years. Wish I could afford one, or the other, or both! :D
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #22
And I was also under the impression that the 3pt hitch and PTO are options as well on the toolcat, not standard equipment.
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #23
Outcross 07511AA Outcross 9060 (With Canopy) $70,178.00
Outcross 07511BA Outcross 9060 (With Canopy and Loader Arms) $81,599.00
Outcross 07511CA Outcross 9060 (With Factory Cab) $83,579.00
Outcross 07511DA Outcross 9060 (With Factory Cab and Loader Arms) $94,999.00
Outcross 41249 Foam Marker Kit $2,295.00
Outcross 07521 1/2 Yard Bucket $899.00
Outcross 07530 Cargo Bed $3,999.00
Outcross 07531 Hood Guard $599.00
Outcross 07536 Pintle Hitch $299.00
Outcross 07540 Inch Mode $999.00
Outcross 07545 Work Light Kit $749.00
Outcross 07546 Beacon Kit $379.00
Outcross 07526 Third Function Loader Selector Valve $1,519.00
Outcross 07527 Second Auxiliary Hydraulic Valve $1,299.00
Outcross 07532 Rear Screen $499.00
Outcross 07542 Road Light Kit & Horn $999.00
Outcross 07547 7-Way Trailer Plug Kit $249.00
Outcross 07548 Foam Marker Finish Kit $429.00
Outcross 07549 Horn Kit $49.00
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #24
Yeaaa, you are limited to about 35hp max out of any hydraulic powered pto...
That's a fair amount, but some like myself, would like more...
SR
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #25
OUCH!
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #26
I know the OP doesn't want to consider a Power Trac, but jeez, a PT1460 is $26,000 new. A new 5610 toolcat is pushing $50 grand!
That's a heck of a lot of money left over for attachments and beer.
The PT1460 lifts 2400# while the toolcat is rated at 1500#(if equipped with optional counterweight option). They have similar GPM and pressure on the standard hydraulics. The PT has 33% more ground clearance at 12" VS 9". The 3pt hitch is optional. The PTO is optional. The high flow hydraulics are optional. It brings the price to $50K.
I can't find the lift height for the 5610. The PT1460 is 8'.
The 1500 pound rating may be related to the way Bobcat rates skid steers. It is half the tipping load.
I checked our 5610 F series with the crane scale, it went over 3000 pounds and the rear with nothing on the 3 point stayed on the ground:
They handle the 1800 pound 7' brush hog easily:
Lift height is 7':
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #27
Thanks! :thumbsup:
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #28
The Toolcat 5610 comes mostly loaded while the 5600 is more base that can be optioned up.
edit: The 3pt and PTO is optional on the 5610 and it seems HO hydro is optional.
Many times the 5610 are optioned out more than the 5600. Why would you chose to not have the 5600 with the box then not get 3pt/pto?
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #29
"Outcross 07511DA Outcross 9060 (With Factory Cab and Loader Arms) $94,999.00"
Wow! My one year old Toolcat 5610 that is mostly loaded with options for $40k was a steal! The one reason I like the Toolcat is the loader is built in and doesn't take up a bunch of extra room. It is like a swiss army knife...lots of tools tucked in a tight package.
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #30
WOW, you could buy a used cat D10 for that price!..
2007 Freightliner M2 106 Medium Duty Pac-Mac RL10 10 Yard Refuse Garbage Truck (A55852)
2007 Freightliner...
2017 Ford E-450 Super Duty Shuttle Bus (A55852)
2017 Ford E-450...
UNUSED FUTURE LASER LEVEL W/TRIPOD (A57193)
UNUSED FUTURE...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
UNUSED FUTURE FT-SE61 61" HYD SWEEPER (A57193)
UNUSED FUTURE...
