buckeyefarmer
Epic Contributor
Inspector got me for venting bathrooms to soffit when i built in 1997.
It is a national code, not everyone follows it.
I've seen the vent piping terminate into the attic also, I'm sure code says it has to be carried outside and worse yet I think each fixture has to be on it's own )other than a whole house unit). That can be a lot of holes. Introducing moisture into an attic space in cold climates can allow it to condense on the underside of the roof sheathing. It also lowers the effectiveness of insulation.I can see where venting to the soffit would create issues. That's where the air enters the attic. Running the vent duct up high to the ridge vent is what I see done in a lot of houses that I work on. This way the natural air flow carries the moist air out of the attic.
Do the panasonic fans have lights too?...
Our fans are vented out of the roof. We used Panasonic fans for the bathrooms and I think the attic fan as well.
The bathrooms have a little room for the toilet. The inspector made us put in fans in that little toilet space.We used cheap contractor fans to meet code but seldom use them but we do use them from time to time....
The only problem with the Panasonic fans is that they are VERY quiet. :shocked::laughing::laughing::laughing: Which is why we bought them.The problem is you can leave them on and forget about them.
So, sometimes we turn on the noisy fan to remind us to turn off the Panasonic fan. :laughing::laughing::laughing:
No way would I vent our bathroom to the attic or any other closed space. When it gets really cold the shower vent will sometime condense water vapor which then drips from the vent. No way would I want that moisture in my attic.
Later,
Dan
Not surprising. I found one not vented to the outside when I remodeled my house. Took a bit of work to snake a vent through and fix it. As an aside, when we remodeled we took the contractors advice and got Panasonic vent fans. They are almost silent and well worth it. I cringe every time I go into an expensive house and hear the economy grade fans.
Replace the switch with a timer. (as has been mentioned in several posts)The only problem with the Panasonic fans is that they are VERY quiet. Which is why we bought them. The problem is you can leave them on and forget about them. So, sometimes we turn on the noisy fan to remind us to turn off the Panasonic fan.
So your exhaust fans often just vent outside air in, probably why many just vent in the attic. Many have flap vent on top but become inoperative with age. Mold in your attic probably caused by something other bath fans.
One without rats, bats, or squirrels I guess. :laughing:
Sure you do, very common. Just insulate.Duct work in the attic must be a Florida thing. You don't see that in cold climates.
