Clutch won't engage L3150
   / Clutch won't engage L3150 #1
Big mak
Kubota L3150
While moving/dumping dirt with my loader, I pushed my clutch in to change gears and back up. I felt something give in the clutch pedal and then was unable to get the tractor to move again. The clutch seems to be disconnected but nothing I see looking at the linkage outside under the tractor seems disconnected. I'm also able to move the shift and drive levers in and out of gear without grinding or depressing the clutch. It does'n't seem to matter whether it's in high or low, in or out of 4 wheel drive. Is what's disconnected possible to fix fairly easily without taking in to the dealer? The clutch has been adjusted several times in the past to continue adequate engagement. Thanks.
Correction. Tractor is an L3250.
   / Clutch won't engage L3150 #3
Hi Big Mark, did you ever figure out the clutch problem. I am having similar issues. Thanks
   / Clutch won't engage L3150 #4
I hope Big Mark replies, but this was the first and last time they posted to the forum.
You might want to consider creating your own post. Also consider describing what's happening in your situation with detail. The better the info, the better the response from the community.
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
Portable Restroom (A54865)
Portable Restroom...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
8" Wilton Vise (VISE ONLY) (A59076)
8" Wilton Vise...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
