Do I have any business trying to use a rotary cutter on this?
   / Do I have any business trying to use a rotary cutter on this? #1
Silverado21
N.A
5.5 flat acres of this, ignore the logs in the middle as its the only spot on the property with them. Id love to buy / rent a bobcat with a proper forestry cutter but that just so expensive. One day of rental is $800 locally for the bobcat and cutter. If I can get away with a rotary cutter and a 25hp tractor that would be ideal since we'll have the tractor forever and the bobcat would only be for a few months. Largest trees we could find are 2-3 inches and softwood the bulk of the work would be the stupid vines and such.
   / Do I have any business trying to use a rotary cutter on this? #2
What's your 25hp tractor? Some call their 25hp riding mower a tractor, or it might be an older full-sized 4000lb ag tractor.
Bruce
Bruce
Not yet purchased, something in the B series Kubota / Yanmar SA 424 arena
   / Do I have any business trying to use a rotary cutter on this? #4
No logs and no trees bigger than about 2" O.D.
Ralph
   / Do I have any business trying to use a rotary cutter on this? #5
I have a 25hp that I clear thickets with. Go around the big stuff when bush hogging and come back with the chainsaw to cut off close to level with ground.
   / Do I have any business trying to use a rotary cutter on this? #6
I think you’d probably much destroy the little tractor doing that. Rent the skid steer and extreme duty cutter.
   / Do I have any business trying to use a rotary cutter on this? #7
I would work on that CAREFULLY with our B7500, you will have to work around the downed logs, but it will chew up brush up to 1.5", its happier with 1" and smaller though, so perhaps work around those and come back with a chain to rip them out, or cut them off.
If you stab a stick into the radiator though, you will spend at least as much as you saved by not renting the bobcat.
Aaron Z
   / Do I have any business trying to use a rotary cutter on this? #8
Silver,
I have a 23HP Kubota BX and my Land looked like that at one point. I run a 48” LandPride rotary mower
My advice is to take your time, walk the property and remove all the big obstacles. Winter is a great time to see what’s hidden in the brush! I think a decent brush hog is about $1500, so if you get 2 days out of it, you’re ahead of renting!!
Go SLOW!!!
Cheers,
BN
   / Do I have any business trying to use a rotary cutter on this? #9
As has been said take your time. Use a chain saw. Protect your radiator. May need to cut in reverse. Hope you are physically able to cut your logs and burn them. Small fires are good for such. May need to spray with 2-4-D to help control brush. If you have a blade or landscape rake they can be used to push what needs to be burned into a pile.
   / Do I have any business trying to use a rotary cutter on this? #10
Borrow a neighbor's tractor for a weekend. Add cheap hydraulic fluid when you rip a hose off, straighten the bent clutch rod, fix the radiator with Gunk, ignore the bent loader frame, set BOTH front tires flat so it won't be obvious one has been de-beaded, patch the ripped seat with yellow or black duct tape and try to drain out some of the fuel when you accidentally put gasoline in the tank instead of diesel. Park in on their lawn so they won't notice the engine oil leaking out of the crimp in the oil pan. Tell them thanks and have a nice day. We'll watch (again) for the abuse complaints here made by your unappreciative neighbor. Tell them you didn't need the rotary cutter so you left it behind the barn. Then see it it's still above the swamp water level where you got stuck and had to drop it off. Cover your tracks with lawn clippings.
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
2020 John Deere 7230R (A53317)
2020 John Deere...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED FUTURE XKH39 39" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
Club Car XRT 1500 (A56469)
Club Car XRT 1500...
