Code54
Elite Member
- Joined
- Aug 20, 2005
- Messages
- 4,407
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I am surprised the tires not bulging out - that is a lot of weight
Some folk need to go back to driver education to learn the gas (and brake) pedals are not binary devices.
I disagree, the Toyota made it partway up and out of the muddy bottom until the tow strap pulled it back down.In the first part of the video, the ford is up high on the bank. The truck slides sidways to the bottom. A normal truck would not have made it out much less drug a Toyota with him.
Some times, your stuck until the petal is mashed to the floor to clean out the tires.
I would expect nothing less from someone who would ruin the capabilities of their truck with a lift kit and tires like that...
At least the Toyota driver was trying to get up out of the bottom of the valley as soon as he could. Not sure why the moron in the Ford is try pulling from up on the side of the hill rather than down in the valley so that he didn't have to go through all that mud again.
How was it clear that the Ford wasn't able to go up the hill? The Toyota was able to get up and from what I saw even get some slack in the tow strap. IMO, the Ford could have done the same if the driver wasn't intent on covering the Toyota with mud to prove how he was "the big man"The driver of the Toyota was not very smart turning towards the hill when the driver in controll was clearly not going to be able to pull him up the side from the beginning. By turning the wheels the wrong way he was just making the tow much harder than it needed to be and forcing the other truck to work harder.
We don't know what happened before the video, perhaps it was agreed to go uphill as soon as possible. With as much mud as the Ford was throwing, the Toyota driver may not have been able to see that the Ford was staying low.The driver of the Toyota should have steered with the truck pulling him not to the hill. I f I was towing you and you did that I would make you get out and let someone who knows what they are doing behind the wheel drive your vehicle or let you stay there!
In the beginning, the Ford looks like it could have used less throttle while backing up once they were through the muddy spot.
IMO, the Ford drove in the bottom specifically to cover the Toyota in mud.
When you are on muddy grass that is not yet torn up, you can often get the same amount of work done with less throttle and damage to the ground if you can keep the wheels from spinning and chewing up the grass.
Aaron Z
