Lift on 3 point seems awfully short.....how to fix?
   / Lift on 3 point seems awfully short.....how to fix? #31
Take a good look at your picture. If you take the pin out of the link at the lower drag link and move it to the rear hole. Then you would have to lift the lower drag link to get the pin to line up,(more height)!!!! If would put the pin in the other way with the cotter pin facing out then the sway adjusters well not hit the pins. You might have to remove sway adjuster to get the pins in. Then you well be just fine..
   / Lift on 3 point seems awfully short.....how to fix? #32
The B2920 did not come with those lower links and sway bars, I'm almost sure it came with chains and a one piece lower drag link. Check and see if you have around 25" from front lower drag link pin to the rear pin.
   / Lift on 3 point seems awfully short.....how to fix? #33
That is what I was thinking too. Some of these parts came from something else. The length of the LH lift link does not match the RH adjustable one either.
Worked on it today. New holes and the last few turns on the adjuster got it there.
Whoever said the parts are not what came with the tractor may be correct as it came to us used.
In any event......another learning experience.......and do know the insights are appreciated.
   / Lift on 3 point seems awfully short.....how to fix? #35
Those parts on the 3pt are a good update, they cost the po good money. Where did you dill the holes? You didn't need to any holes, just move to the other hole.
Stirrups had room to drill a new hole above the ones that were there. Added near on 2 inches at that point which translated into by far the greatest portion of what solved the problem.
   / Lift on 3 point seems awfully short.....how to fix? #37
Good!! One other ? When you take the mower off see if the 3pt well go all the way down without hitting the lower link.
   / Lift on 3 point seems awfully short.....how to fix? #38
Pics?
2025 Spirit 48V 1000W All Terrain Electric Bicycle (A55853)
2025 Spirit 48V...
UNUSED FUTURE 32" HYD TILT MINI EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 32"...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
Toyota Forklift (A55973)
Toyota Forklift...
2013 YAMAHA RHINO 700FI UTV (A57192)
2013 YAMAHA RHINO...
2014 John Deere 204K Wheel Loader (A53485)
2014 John Deere...
