What to watch out for and check on a tractor that has sat for five years?
   / What to watch out for and check on a tractor that has sat for five years? #1
FiveMikesOut
SC
2005 New Holland TC35A
Hello,
I recently bought a TC35A NH tractor that had sat for five years before I bought it. It's last oil change happened in 2013, and only 25 hours have been put on it since then. Are there any major things to look out for with this machine?
   / What to watch out for and check on a tractor that has sat for five years? #2
Is the engine stuck/seized? If not, will it run?
   / What to watch out for and check on a tractor that has sat for five years? #3
Congrats on the purchase! Did the tractor sit inside or outside? How many total hours are on it? What was it used to do by the previous owner? Did you get a maintenance log from the previous owner?
   / What to watch out for and check on a tractor that has sat for five years? #4
Look for problems with hoses and tires. Rubber ages.
No, the tractor runs perfectly and started up immediately.
Thank you! It sat inside a shipping container that was seldom opened. It has 350 hours on it. The previous owner used it for loader work and cutting his yard for the most part. I did not get a maintainence log with the tractor.
I will make sure to do that.
   / What to watch out for and check on a tractor that has sat for five years? #8
..................... It has 350 hours on it. ............................. I did not get a maintainence log with the tractor.
With 350 hours, there can't have been much maintenance to log.
   / What to watch out for and check on a tractor that has sat for five years? #9
Since it was kept in a shipping container, it should be in near perfect condition. Id change the fluids and filters and lube every moving part. Make sure the battery terminals are clean. Maybe wash and wax the tins to keep them looking good.
   / What to watch out for and check on a tractor that has sat for five years? #10
Hmmmmm,15 year old tractor with only 350 hours on it? Most likely suffering "Dry Rot" and other problems you will never be able to overcome. Post your location and one of us will take it off your hands before it fall's in staves.:licking:
Swict 84" Quick Attach Bucket (A56469)
Swict 84" Quick...
(INOP) 2019 JOHN DEERE 344L WHEEL LOADER (A52707)
(INOP) 2019 JOHN...
2006 Mac 35ft Tri-Axle Dump Trailer (A55852)
2006 Mac 35ft...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
ANTIQUE GAS FIREPLACE HEATER (A57192)
ANTIQUE GAS...
12' CONTAINER (A57193)
