Grading Is a GC1705 box blade combo going to work?
   / Is a GC1705 box blade combo going to work? #11
Thanks. Looks like the top link is no longer stocked.
   / Is a GC1705 box blade combo going to work? #12
Just source a ram with the same dimensions elsewhere, actually if I did it over again I’d probably shorten overall retracted length by an 1”
   / Is a GC1705 box blade combo going to work? #13
Just source a ram with the same dimensions elsewhere, actually if I did it over again I壇 probably shorten overall retracted length by an 1納/QUOTE]
dneal, I hought I found the same top link on the Surplus Center site just yesterday but maybe I was wrong. GC1710, I noticed that the retracted length of the manually adjusted top link on my tractor was about an inch shorter than the cylinder you used and I was wondering if it made any practical difference. Sounds like it might and thanks for your comment on it.
Also, I see that SC offers a version of the valve that has a float position for an exrea $100. I知 trying to think of a case where a floating top link would be useful?
   / Is a GC1705 box blade combo going to work? #14
A side-link float option would be good for following ground contours. I’m sure there is some top link float reasons, but I can’t think of any.
Thought I would post a before and after picture using the 48" box blade I picked up used. Makes you a little nervous as you are working it because it gets worse before it gets better.
Would have liked to keep going but I ran out of daylight then it snowed. The strangest part is it feels like you are just dragging gravel back and forth. In reality you are digging up the old gravel.
   / Is a GC1705 box blade combo going to work? #16
Not bad for 1st time use and only manual adjustment.View attachment 579160
Looks good!
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2011 Chevrolet Cruze Sedan (A56859)
2011 Chevrolet...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
