Brand new L2501 started making a nasty noise at 6 hours
   / Brand new L2501 started making a nasty noise at 6 hours #71
Could be anything but it looks to me like the remains of a small hog ring. Anything on (or near) a Kubota that gets a crimped fastener?
Z.
   / Brand new L2501 started making a nasty noise at 6 hours #72
Wow, something got in there.. almost looks like a staple from a box, but could be anything I suppose. It is hard enough that it dented both piston and head... have then given a estimate on how long before you get your tractor back?
   / Brand new L2501 started making a nasty noise at 6 hours #73
Stuff like this is **** for process improvement folks. At least it is to me :D
:laughing: yeah the folks in QC will have a hot topic and be writing new procedures in no time.
Overall a good thing -since it may save another buyer headaches/stress and improve the infant mortality rate/customer satisfaction for Kubota.
   / Brand new L2501 started making a nasty noise at 6 hours #74
I still figure that the mfr ran the engine a while before installing it in the tractor and heard nothing. Also since Arclight only ran it 60 seconds or so after the noise started. I'm still thinking that the offending clip/staple/piece of metal was lying there somewhere in the intake area closer the intake valves than the air filter and was ingested during the first 6 hours of operation. Maybe in the intake manifold, maybe in some of the air hose leading from the air filter to the intake, who knows. At least from the photos it doesn't look like a casting rim or fragment. Seems unlikely that it could have bounced around in there (say inside the combustion depression in the piston top) and then eventually bounced out on top of the flat part of the piston where there was no clearance. And it sure did not go through the air filter.
1200 times this thing was hammered into the head just in that time alone.
I think you're right though, intake manifold where the hose connects to it, or debris in the hose itself during assembly. Certainly behind the air filter and most likely over the hump under the hood, the air velocity has to be pretty low in there.
   / Brand new L2501 started making a nasty noise at 6 hours #76
I have personally seen staples in both air filters and hoses. Not sure why.
   / Brand new L2501 started making a nasty noise at 6 hours #77
Yeah, I never thought of that. Maybe it was in the folds of the filter, then worked its way in.
   / Brand new L2501 started making a nasty noise at 6 hours #78
Maybe the staple held a parts number tag or could of fell off a air filter package who knows but I am sure they'll find out and change procedure so it doesn't happen again.
   / Brand new L2501 started making a nasty noise at 6 hours #79
So, the tapping noise was it trying to staple itself?
:: groan ::
   / Brand new L2501 started making a nasty noise at 6 hours #80
Hate to be the person going through all those intakes and filters right about now..
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
Giyi 61" Sweeper (A57149)
Giyi 61" Sweeper...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58374)
KNOW BEFORE YOU...
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2015 Komatsu PC490LC-11 Hydraulic Excavator, S/N A42603, PIN# KMTPC251HFWA42603, Turbo Diesel (A59076)
2015 Komatsu...
