Can I use this log clevis on a chain for equipment tie down?
   / Can I use this log clevis on a chain for equipment tie down? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I often haul a 4,500 or 5,000 lb tractor on an 18' equipment trailer and have used one strap at each corner for tie down. It works great and nothing ever moves. I have tow hooks I installed on the front of the tractors and using straps with hooks makes hookup quick and easy.
Now I am switching to chains and have just been looping the chain around the front weight bracket. That is, until today when I discovered some log chain hooks I have and learned they slip onto my front hooks I installed for the traps. I could easily put those hooks on my 5/16" grade 70 chain and could hook up real easy.
Two questions come to mind. One, is this a good idea? Second, how can I find the weight rating on these hooks? I believe they are grade 70 but can't find anything on the net. Any advice appreciated.
   / Can I use this log clevis on a chain for equipment tie down? #2
I use the type in picture 3 for hooking on my tractor when jerking trees down and never had one fail or even bend. Just make sure the bolt doesn't unscrew.
   / Can I use this log clevis on a chain for equipment tie down? #4
I reckon that it will work fine... the weak point would be the shackle used.
I'd recommend a Grade 'S' bow shackle (you can mouse the pin to ensure it doesn't unscrew) but the important thing is the strength of that shackle. Here's what is used in Australia: https://www.beaver.com.au/documents/info/Beaver_Trailer Chain Shackles 2014_LR.pdf
By the way, that's a beautiful paint job on those front weights! :rolleyes:
Yes, a remarkably high quality job and of the correct color I might add. If only someone could have tipped me off to the correct color early on. :D
A "Bow" shackle is what I used on the tractor and the size was limited by the diameter mounting hole I had to work with. I removed the screw in shackle bolt and replaced it with a grade 8 bolt, double nuts and Loctite. It's the log hook that slips right into it and if safe enough will sure make hooking up easier when towing. Hauling a tractor is not an easy thing.
   / Can I use this log clevis on a chain for equipment tie down? #7
I can't open this site without downloading something. I suspected grade 8.
Any way to copy and paste the info?
I haul mine a lot and did the same thing on the front , used D rings with grade 8 bolts and nuts, Have a cotter pin through the end of the bolt so the nut cant back off. I use these hooks on the end of each chain that hooks onto the D ring, the other end has a standard grab hook.
1/2 Clevis Slip Hook - Grade 7 [CSH12]: Ratchet Straps, Tie Down Straps, E Track Tie Downs, Moving Blankets & Pads, Cargo Straps, U.S. Cargo ControlView attachment 568454View attachment 568459
I would use that kind of hook but there isn't clearance because of the way my clevis hooks are mounted. Maybe I could use in the back of the tractor where I have more room. Thank you.
   / Can I use this log clevis on a chain for equipment tie down? #9
View attachment 568392 View attachment 568393 View attachment 568394
It does not look like it is made for a straight pull in tension. Don't be surprised when it breaks when hitting a bump in the road that can compound the tension factor. Used as a chain choker the stress is on the base of the casting/forging not halfway out the shank where it gets smaller. For the price of standard hooks why take a chance?
Ron
   / Can I use this log clevis on a chain for equipment tie down? #10
Ron
AGREED !!!!
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
2020 DRAGON ESP...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
HUSQVARNA RIDING MOWER (A52708)
HUSQVARNA RIDING...
2014 F-150 STX (A56435)
2014 F-150 STX...
2007 CHEVROLET KODIAK C4500 (A58214)
2007 CHEVROLET...
