ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,445
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
With engine running, you should be getting voltage in the 13.1 range, which allows for charging battery. Also, remove ground wire at frame and sandpaper both ends. Reattach and recheck. You would not believe the number of times ive found poor grounding to be an issue
^^^Yes, check this to see if your charging system is working!
