How often do you change anti-freeze on Kubotas?
   / How often do you change anti-freeze on Kubotas? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
How often do you change anti freeze on 25 to 70HP Kubotas. I know the book says 2 years but does the advent of extended life anti-freeze change that? Kubota now has extended life A/F too but I have not seen any.
Also, what kind of anti-freeze do you use? Since it's not a wet sleeved engine, I have used either Deere anti freeze or just the 5 year Prestone XL stuff.
How often do you change and what A/F do you use?
   / How often do you change anti-freeze on Kubotas? #2
Every 3 years, or more if it's in a dusty environment. I use Shell ELC. Love it, I use it in all my vehicles.
I also change the hoses and rad cap every 5 years.
   / How often do you change anti-freeze on Kubotas? #3
5 years or 5000 hrs. Test it and you can extend it even longer, providing you use etl antifreeze.
   / How often do you change anti-freeze on Kubotas? #4
I've used Zerex G-05 in the tractor and Jeep for six years now with no ill effects. I changed the stuff in both last year, after five years. Its listed for heavy duty diesel use. I read somewhere that there is a company making an antifreeze that they rate as "lifetime". Can't remember who and I've never followed up on it. I'd be just a tad bit concerned - nothing lasts a lifetime anymore - - at least not the newer stuff. Its called - - "engineered obsolescence".
   / How often do you change anti-freeze on Kubotas? #5
I just switched mine to Peak Final Charge Global. It is compatible with all types of coolant and does not require a flush and as long as you have at least 70% of it, they say that is as good as 100%.
That is why I switched to it, so I don't have to stock different coolants for all my stuff.
Don't quote me on this, but I think it said it is good for 5000 hours or 8 to 12 when test strips are used.
   / How often do you change anti-freeze on Kubotas? #6
I use Peak Final Charge Global in all my diesels
Could you use Peak Final Charge Global in a 1960's farm truck with metal--copper, brass-- radiator?
   / How often do you change anti-freeze on Kubotas? #10
I also use Zerex G05 in my Kubota’s, mostly for the 5 year service interval. Standard green every 2 years would be a pain.
2016 BOBCAT T550 SKID STEER (A52709)
2016 BOBCAT T550...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
1991 FORD F-800 BED TRUCK (A58214)
1991 FORD F-800...
2018 NISSAN Sentra Sedan (A56859)
2018 NISSAN Sentra...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
