What is user UNFRIENDLY on your tractor?
   / What is user UNFRIENDLY on your tractor? #131
It would help if the knob for Cruise Control was a different shape than gear range (L-M-H) knob which are right next to each other on my Kubota so I wouldn't to look down to see which I'm grabbing.
Why not just slip a sock or something over the one you use the least? Or you could wrap some tape around it.
Welcome to TBN! :)
   / What is user UNFRIENDLY on your tractor? #132
Does your tractor have something you would also consider to be user unfriendly?[/QUOTE]
The 3pt hitch and all the wonderful attachments allow so much work to be done. With so much variety in my arsenal, both purchased and hand-made it would be nice that the control could have a real positive stop to hold the arms EXACTLY where you want it. Deere chose a little plastic lever with a cam to "lock" the position. Far too insufficient when there's 100's of pounds hanging back there, or mowing, or dragging, etc etc. I WILL come up with something.
   / What is user UNFRIENDLY on your tractor? #133
My mid 1980's JD 650 has a 1/4" bolt and wing nut,,, which results in a positive stop,,,
I am amazed how accurately it repeats,, NO guessing.
   / What is user UNFRIENDLY on your tractor? #134
   / What is user UNFRIENDLY on your tractor? #135
I am jealous of that, and it is one of the things I find very user UNfriendly on my Kubota B2320...
The 3-point control lever only controls making the 3-pt go up and down, it doesn't control how far it goes up or down.
It does kind of control how fast it goes up and down, but only when you unscrew the really-hard-to-reach, grab-tightly-enough-to-turn smooth [unknurled] "speed control" knob located just above the foot pan, below the seat dead-center between my knees.
Which with sweaty or greasy, or even cold hands is a royal pain to grip that tightly- never mind if you have carpal tunnel problems.
   / What is user UNFRIENDLY on your tractor? #136
Whoever designs PTO connections for implements should be shot. "Squeeze and pull back on the sleeve while pushing and slightly turning the implement connection onto the tractor's shaft?" Gimme a break! I'm a 70+ year old woman with small hands. I have to have someone with big strong hands to install most implements on my tractors. I am able to do most of the pin types. I keep pliers around so I can pull cotter pins. I believe machines are supposed to HELP us, not frustrate us to death!
What I did with the pto collar on my rototiller was replace the spring with a lighter one. I can't tell you where I got the spring as it came out of my "spring" box.
It made the pto shaft substantially easier to attach.
I agree with the "should be shot" part.
   / What is user UNFRIENDLY on your tractor? #137
PTO, PTO and PTO LoL, I have a 2005 JD 4320 and it was a flipping fight to hook up the PTO, everytime. My buddies old ford slips on no prob.
   / What is user UNFRIENDLY on your tractor? #138
The water separator drain on my NX5510 sucks. It's right above several hoses and hard to get anything under it to catch the draining liquid. Never want to get fuel on hoses (w/o washing off). And then there's a fairly well noted issue of the front radiator screen only being able to be slid out from one side.
And on my B7800 there's the infamous loader cross bar right over top the fuel cap area. This in itself gave me the motivation to get a fuel storage tank with pump: trying to hold up 5 gallon jugs of fuel, especially with the stupid environmental dispensing claptraps attached, was a huge pain. Oh, and the "Quarter Inching Valve" for the 3pt- keeps you four-quarters guess how high up the 3pt hitch is! (nothing like having the real thing- sliding the 3pt level to the same position to get the same results!)
CATERPILLAR 22" PIN ON BUCKET (A52707)
CATERPILLAR 22"...
Forward 10,000lb Two-Post Electric Auto Lift (A55852)
Forward 10,000lb...
cummins generator (A56857)
cummins generator...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
(8) 12" X 22# UP TO 113" I-BEAM (A57192)
(8) 12" X 22# UP...
