What's This On The Power Pole?
   / What's This On The Power Pole? #21
It is a line switch feeding the single phase tap.
From there the wire goes down to the vertical devise which is the knife switch/fuse [ poor picture ].
Yea, the pic sucks, wish I would have bought a good digital camera back when I had money. I do, however have a drone, and I feel a mission coming on.
   / What's This On The Power Pole? #23
It is pallet tracking device.
I thought that was classified!
It's only the antenna for a pallet tracker.
They have been doing a "catch-tag-release" operation on the wild pallets to more closely monitor their movements. The wild pallets essentially get an enhanced RFID tag.
   / What's This On The Power Pole? #24
If it's connected to the power line and ground, it's a lightning arrestor. See lower right of pic
On our power line there is protectors like this every house tap to prevent the transformer being destroyed by lightening.
This includes the protection on transformer. line switch.
Sure can tell the generation difference in answers . and to think this is our future leaders.
ken
   / What's This On The Power Pole? #25
Since it is bell shaped and stood off from the pole, I'd go with the lightning drain thing. Not that lightning can't jump the distance to the pole...
   / What's This On The Power Pole? #26
What coobie said, it痴 a single phase tap. With a fused cutout on the cross arm.
   / What's This On The Power Pole? #27
I so wish I was with the co-op out here. My neighbors pay less than half of what I do for electricity. If I spent $12k I could get a line here, but I'll probably be dead before it pays off.
Sure wish I had that option.
   / What's This On The Power Pole? #28
Are you talking about the white dome shaped object? If so it's just a 25kv porcelain insulator. It's being used to support the phase (hot) conductor that serves your property. The oval shaped device on the crossarm is called a cutout. The skinning side of the cutout is the fuse barrel, which contains a one time use fuse. The single phase is tapped off the main 3 phase using a hot line tap, connects to the cutout, comes out the bottom of the cutout to the porcelain insulator and then over to the next pole towards your property. The wires below all that are neutrals. So the system that feeds you is a grounded-wye system. In my area of operation we run a 7,200/12,470 volt system. If you measure between the phases you with get 12,470 volts. If you measure from any of the single phases to the neutral you will 7,200 volt.
   / What's This On The Power Pole? #29
Yeah, I liked the pallet answer, but coobie is probably right, he used to be a lineman.
John Deere 7000 8 R Planter (A50515)
John Deere 7000 8...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
BHARAT ENTERPRISES PARVEEN ALL PURPOSE PLOW (A51243)
BHARAT ENTERPRISES...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
