won't start after overturning my tractor
   / won't start after overturning my tractor #1
dwana7
I have an LS U5030c 2011 - I just turned it on its side and after getting her upright it won't start so is there a kill switch or a reset or anything? any info is appreciated
   / won't start after overturning my tractor #2
Yikes. Were you on it when it went over? If yes, you ok?
Sorry I don't have any suggestions regarding the starting problem.
   / won't start after overturning my tractor #3
If it ran for a bit before you shut it off, it's possible you got air in the fuel line. Have you bled the fuel lines?
That's a pretty good sized tractor to put on its side. We all want to know how it happened, how you (and the tractor fared), how you righted it, and for extra credit, what two words you said when it started to tip.
   / won't start after overturning my tractor #4
Does the engine turn over with the starter? If not it probably has oil in the cylinders.
Was brush hoggin on a field I do 4 times a year...the grandson had been on it and had it out of 4wheel drive and my dumbas.. didn't check it...she skidded like a sled on ice I am fine a small gash on top of my head is all= tractor side glass broke out and crumpled the top of the cab exhaust side...hit a few bumps n a hole n the tall weeds that tilted her or I may have been able to ride it to the flat bottom- set her up w/a d9 dozer n I said lots of pretty words but I think oh ****tttt was the first lol
   / won't start after overturning my tractor #6
Important clarification before any sound advice can be given......
Does the engine crank (turn with the starter) and not start, or does it not crank?
nope no crank going to pull injectors- thanks for idea
   / won't start after overturning my tractor #9
If it was on its side a "while" there could be enough oil in a cylinder to "lock" the engine.
My nephew locked a Duramax with just a little extra fuel (long story)
make sure the engine is not locked, some may call it hydrolocked.
40' High Cube Multi-Door Shipping Container (A56469)
40' High Cube...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2015 Caterpillar TL642C (A53317)
2015 Caterpillar...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
2021 Club Car Carryall 500 Electric Utility Cart (A55851)
2021 Club Car...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
