CK25 ticking sound when ignition off
   / CK25 ticking sound when ignition off #1
paulbr
St-Colomban, QC
Kioti CK25HST
Hey gang
My CK25HST (2007 @ 600 hr) started an intermittent ticking sound; like a flasher, but twice the frequency?!?!
It's been sitting outside since this spring. But I had noticed this in the garage after snow blower in heavy wet snow; suspect humidity related issue ??
Thanks
Paul
   / CK25 ticking sound when ignition off #2
This sounds like a relay short of sorts. Let it dry out for a day or two and see what happens. I've had an assortment of electrical problems similar to this after a hard driving rain, having left the tractor outside. Just needed to dry out. Most open station tractors do not like its console left out in the rain. I would recommend getting a cover for the console if leaving the tractor outdoors.
   / CK25 ticking sound when ignition off #4
Does it do it right after shutting it off, and for how long does it do it?
   / CK25 ticking sound when ignition off #6
Some metals also will make those type sounds while cooling down.
Is that a possibility?
That’s were I was going too as to why I asked what I did.
   / CK25 ticking sound when ignition off #7
My neighbor called me last summer and said that my CK20 was making a ticking sound. I found the flashers turned on (grandkids) but the lights weren't flashing because the key was turned off.
RSKY
Does it continiously when shut off. I have now put it in the garage and disconnected battery before going crazy from the sound. Will try a hair dryer under the dash...
   / CK25 ticking sound when ignition off #9
Ok, yeah I wouldn’t leave it with the battery connected until you find the problem. If it’s making a noise then you should be able to track it down , once you find the general area of the ticking, then start feeling around on everything, you should be able to feel it if it’s a relay or something.
2017 Ford T350 van (A55973)
2017 Ford T350 van...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2019 Yongfu Scooter (A55853)
2019 Yongfu...
30KW GENERATOR (A58214)
30KW GENERATOR...
