4720 Power Steering Intermittently Locks Up
   / 4720 Power Steering Intermittently Locks Up #31
Ah. My bad. Doesn't the front pump feed the hydro and steering and on the 4x10 series the pto and 4x4. I would check the steering psi. It has its own pressure relief. Could be sticking I would guess. I would pull it and clean it then test the pressure.
But to continue that thought maybe it is getting air in. Even with no pressure coming in your wheel should still be trying to push the fluid in the power steering valve. Any chance you have a mechanical issue with the steering column to the valve?
   / 4720 Power Steering Intermittently Locks Up #32
Well, the thread is pretty old...but the first thing I'd check would be the front tires inflation pressure
2025 CLG72 72in Dual Cylinder Log Grapple Skid Steer Attachment (A55851)
2025 CLG72 72in...
2006 KAWASAKI MULE 3010 DSL UTV (A57192)
2006 KAWASAKI MULE...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
(15) 1 RANCH 1RGPM GROUND PROTECTION MATS (A57193)
(15) 1 RANCH 1RGPM...
2013 KUBOTA RTV900 XT (A57192)
2013 KUBOTA RTV900...
