New CK 3510 SE questions
   / New CK 3510 SE questions #1
steviep
Milton NH
2001 JD 4300
Received my new tractor yesterday and have some questions.
1. I found a couple of wires in back by the seat, can these be used for running extra lights. Also what is the max wattage they recommend for the lighting system.
2. What type and size are the hydraulic fittings for the rear remotes.
3. Does Kioti have a web page to lookup parts and order from.
I had a JD the last 17 years and I knew the answers to these questions but now I get to start all over.
   / New CK 3510 SE questions #2
There are (2) Bullet Connectors in the wire harness to the right and behind the operator seat. The bullet connectors are powered from the key switch for work lights.
Work light wattage varies these days due to LED's. Size the lights for about a 7 amp draw.
The rear hydraulic plugs on the KIOTI Rear Remotes are 1/2" ISO 7241-1A Plugs, which crosses to the Pioneer 1/2" Poppet style plugs.
The KIOTI webiste does not have a parts order page. KIOTI Parts are sold through the KIOTI Dealer network. We have a Parts-Finder and On-Line Look-up and Order Store on our website at Home Michigan Iron & Equipment Morrice, MI (855) 265-459.
Hope this helps
Thank you, thankfully with better led technology we are getting brighter lights that draw less amperage compared to incandescent lights. I'm an electrician by trade. I found the connection on the right side but I also found a double female weatherproof connector on the left side do you know what that for.
Thank you for the rest of the information.
UNUSED SDLANCH SDL25 RIDE ON DUMPER (A57192)
UNUSED SDLANCH...
(INOP) KUBOTA RTV900 UTV (A57192)
(INOP) KUBOTA...
FUTURE FT-ZWB BACKHOE DIGGING ARM (A57192)
FUTURE FT-ZWB...
2019 Caterpillar 259D (A53317)
2019 Caterpillar...
GAS POWERED WATER PUMP (A52707)
GAS POWERED WATER...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
