?? About octane for mowers and chain saw
   / ?? About octane for mowers and chain saw #161
I have a 2010 ford car with 200k and around here you can only get e10 gas
   / ?? About octane for mowers and chain saw #162
I don't think anyone is claiming you can't put e10 in 20 years old or newer vehicles. I've never seen a problem caused by ethanol on a frequently driven vehicle.
   / ?? About octane for mowers and chain saw #163
I do not know why I read threads with the following subjects and circular discussions, but I do:
The best engine oil
HST vs Gear
Ethanol vs non ethanol
Ecoboost or non Ecoboost
Did I miss any?
:reading: :reading:
   / ?? About octane for mowers and chain saw #164
The engine isn't prone to detonation because you're using the fuel it was designed for. It's prone to detination because of bad timing, too high compression, too lean of a mixture, improper engine cooling, etc... all of which are causes of the problem, not the fuel. If you tuned the engine back to factory specs, made sure the correct spark plug was installed, made sure the cooling passages around the engine are clear, etc... you'd have no problem running the engine on the fuel it was designed to run on.
99 times our of 100, the owner messes with the carb, changes the settings, puts in the wrong plug with the wrong gap, wrong fuel, too much oil in the gas mix on two-strokes, plugged air passages around the engine, etc... it's user induced problems, not the use of the recommended fuel.
And we're talking about smal engines, automobiles, tractors, anything that runs of gas and E10.
Too much two stroke lube oil is a killer . Can稚 seem to explain that to most folk as they know that since none is bad , then more must be better .
   / ?? About octane for mowers and chain saw #165
I don稚 know why I read threads with the following subjects and circular discussions, but I do:
The best engine oil
HST vs Gear
Did I miss any?
:reading: :reading:
R1 vs R4:)
   / ?? About octane for mowers and chain saw #166
The best engine oil
HST vs Gear
Did I miss any?
:reading: :reading:
Diesel vs gasoline . Unleaded gasoline, old equipment and lead substitutes. How to prevent diesel fuel waxing in cold weather. Snow blading vs snowblowing. Rotary three phase converters vs a VFD. Fuel mileage and gallon per hour for equipment . Different types of hats . What is the best deer, moose, mouse, squirrel, coyote and bear caliber. Not necessarily the same one size fits all caliber for the examples. Is a tomato a fruit or a vegetable ? The proper recipe for SOAS and it’s variations . Lager vs Pilsner vs ale vs stout vs porter . Bottled vs cans vs draft . Whiskey is mentioned on occasion but not much debate as it is universally accepted that Crown Royal is the best North American rye/whiskey/hard liquor.
   / ?? About octane for mowers and chain saw #167
The best engine oil
HST vs Gear
Did I miss any?
:reading: :reading:
Diesel vs gasoline . Unleaded gasoline, old equipment and lead substitutes. Snow blading vs snowblowing. Rotary three phase converters vs a VFD. Fuel mileage and gallon per hour for equipment . Different types of hats . Is a tomato a fruit or a vegetable ? The proper recipe for SOAS and it’s variations . Lager vs Pilsner vs ale vs stout vs porter . Bottled vs cans vs draft . Whiskey is mentioned on occasion but not much debate as it is universally accepted that Crown Royal is the best North American rye.
You left out the most important of all... what's the best deer rifle?
   / ?? About octane for mowers and chain saw #168
Diesel vs gasoline . Unleaded gasoline, old equipment and lead substitutes. Snow blading vs snowblowing. Rotary three phase converters vs a VFD. Fuel mileage and gallon per hour for equipment . Different types of hats . Is a tomato a fruit or a vegetable ? The proper recipe for SOAS and itç—´ variations . Lager vs Pilsner vs ale vs stout vs porter . Bottled vs cans vs draft . Whiskey is mentioned on occasion but not much debate as it is universally accepted that Crown Royal is the best North American rye.
Lager vs Pilsner vs Stout vs Porter does not belong on the list. Porter is the only beer worth discussing :drink: :applause: :cool2: :applause: :drink:
   / ?? About octane for mowers and chain saw #169
And the best North American Bourbon is . . . Jack Daniels, Evan Williams . . . . ??? LOL
183 (A52705)
183 (A52705)
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
