Amalie Ultra All-trac 245?
   / Amalie Ultra All-trac 245? #1
cowbridge
Member
Slower Lower, Delaware
Kioti CK2610HST Woods BB60XC
I'm only 30 hours deep into my ck2610. I did a quick fluids check and noticed my font axle oil was low.
Stopped into my dealer to see what they put in it and to buy some.
They use Amalie Ultra All-Trac 245 which is not listed in the book. Anybody have any experience with it?
   / Amalie Ultra All-trac 245? #2
I believe as long as it meets the specs of the fluids mentioned in the book you'll be fine. Someone can correct me if I'm wrong but most UTF fluid is 10w-30 in weight? If in doubt, just drain it and replace with a fluid you feel comfortable with? The front axle holds just under one gallon. I know Kioti does not require replacing the axle or Hydro fluid at 50hrs but I got the factory stuff out of the tractor when I change the hydro filters. It had a fair amount of fillings in it.
Thanks
   / Amalie Ultra All-trac 245? #5
Yep, reading the specs will tell you what you need to know. This mention of Amalie brings back old memories. Seems we seldom hear of Amalie now-a-days, but about 62 years ago, it was advertised and we heard of it frequently. The problem was that the well known Amalie was a non-detergent oil and that wasn't bad for the OLD cars, but the newer ones had hydraulic lifters and a detergent oil was required. I don't know how many times mechanics showed us engines torn down and said the only problem was using Amalie motor oil. Amalie made a detergent oil even back then, but it wasn't advertised. Some companies used the same NAME for their detergent AND non-detergent oils, while other companies even used a different name. For example, "Texaco" motor oil was non-detergent, but Texaco's "Havoline" was their detergent oil.
2018 Ford F-550 Versalift Stamm ATR45N 40ft Bucket Truck (A55852)
2018 Ford F-550...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
New Holland 650 Hay Baler (A53317)
New Holland 650...
HOOD FOR KUBOTA L3302 (A57192)
HOOD FOR KUBOTA...
