Kubota M7040 with Loader hydraulic connections
   / Kubota M7040 with Loader hydraulic connections #1
golfgooroo
Member
Recently picked up a new to me M7040 with 1000 hours and I'm excited to jump in size from the L3130 I had before. When purchased at an auction, I noticed the hydraulic connection at the bucket for a thumb and thought it was much easier and better than what I had done previously. However, I not sure how the thumb hydraulics are actuated. I DO NOT see a second hydraulic lever and only see additional electric buttons on the joystick that I do not think are related. Any help is appreciated.View attachment M7040.bmpView attachment M7040 2.bmp
   / Kubota M7040 with Loader hydraulic connections #2
Sounds like the factory third function set-up;I have one on my L4240.Buttons work the thumb;no levers.
   / Kubota M7040 with Loader hydraulic connections #3
On my Kubota loader, there's a single push button lower down on the stick that is "on/off" for the elec. to power to the 3rd function valve. It lights up when the power is on that supply's the 2 smaller almost "rocker" switch up by the knob on the stick that is the actual valve control.
   / Kubota M7040 with Loader hydraulic connections #4
Yep, buttons on the joystick run the 3rd function hydraulic couplers at the front of the FEL. Great setup. True 3rd function up to the capacity of the pump.
The buttons control a double solenoid valve. Probably located under your right foot when sitting in the seat.
You are very fortunate to have that system. It's very handy and functions flawlessly.
Now go buy more FEL accessories. :)
   / Kubota M7040 with Loader hydraulic connections #5
Good point Eric. If your system isn't working you've probably bumped that switch and turned it off. The design is a bit lacking and is very easy to accidently turn off and not know it.
True purpose is to deactivate the joystick buttons when not using an attachment so the system isn't deadheading pressure if you bump one of the buttons.
   / Kubota M7040 with Loader hydraulic connections #6
100% correct,I forgot about the "power on" button.Kubota factory third function would cost about $800.
   / Kubota M7040 with Loader hydraulic connections #7
Interesting, I have an M7040 with a Kubota loader and the neat little switch that allows me to run a grapple, siphoning off fluid from one of the other movements to run a third function. Anyone have a picture of the electric cut-off switch? I don't remember seeing one, and am not near my tractor at the moment.
David from jax
   / Kubota M7040 with Loader hydraulic connections #8
See the little white button right and low in the pic. It's on the joystick stem.
   / Kubota M7040 with Loader hydraulic connections #9
Mine doesn't have that little switch, mine has a switch up on the top side of the handle for the loader. It diverts pressure electrically when it is pushed, and from what I can tell, doesn't do anything when it isn't pushed.
Thanks for the picture Ovrszd!!
David from jax
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
