   / Share Pics of People Hauling or Towing Something Wrong #6,621
The mine would have already had a permit to mine coal. They were in the pit so most likely no run off. They probably didn't need the government involved at all. They just didn't want to tear up a multi million dollar machine.
   / Share Pics of People Hauling or Towing Something Wrong #6,622
The big difference between the freeway and the dragline was who owned it, freeway is the governments(assuming federal) and they are quick to suspend or change the rules for their own projects!
The dragline, a private company, not so much.
And i imagine building freeway has been done a few more times then a one off salvage.
   / Share Pics of People Hauling or Towing Something Wrong #6,623
I don't understand and have never seen the towing cable mentioned earlier that is on some John Deere and other tractors. Where is this cable and any model numbers so I can look at one and see one? It doesn't seem right that you could rip a tractor in half just by pulling with it but maybe I'm behind the times.
   / Share Pics of People Hauling or Towing Something Wrong #6,624
My nephews have it on a 9230. I have seen it on a variety of other JDs but I am not sure of the numbers.
   / Share Pics of People Hauling or Towing Something Wrong #6,625
Deere 9230 is a big tractor. I'll take a look at one the next day or so. I never knew this. Thank you.
   / Share Pics of People Hauling or Towing Something Wrong #6,627
   / Share Pics of People Hauling or Towing Something Wrong #6,628
Are the cables only on the articulated tractors? You can see one on this big boy:
Nope, this guy has one too:
   / Share Pics of People Hauling or Towing Something Wrong #6,629
In Holland where there are areas of slushy peat soil on top of beach sand, people have been hiring contractors to plough sandy subsoil through the peat. Usually two tractors towing. Especially near the headland where the tow tractors start to turn, the plough tractor was prone to snap in half right behind the bellhousing where the gearbox is narrow. They all use a tow cable attached to the 3pt mounted plough, underneath the tractor.
On clay soil too heavy to grow potatoes they do it too: then the extra power used to come from a 23 ton Cameco 805 which would spin the rims in the tires... on peat they just didnt dare using it, so several standard tractors were used to tow..
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
