Ford 3910 with oil leakeage
   / Ford 3910 with oil leakeage
Join Date
Jul 2017
Posts
9
Braga-Portugal
Ford 3910
Default Re: Ford 3910 with oil leakeage
Hello all,
This weekend i will start the repair of this oil leak, but i still have a doubt.
Is the seal you mention inside the rear axle or is this seal the one that can be seen in the picture above where the brake lever gets inside the rear axle.
Once again, thank you all for the help.
   / Ford 3910 with oil leakeage #12
Join Date
Jul 2017
Posts
9
Braga-Portugal
Ford 3910
Hello all,
The seal is external to the axle housing. It's a rubber cup like device that the brake rod goes through. It seats in the hole in the axle housing from the outside.You do not have to remove the axle housing. Drain the transhydraulic fluid out to get the level below the seal. Just disconnect the brake rod from the external linkage and use a screwdriver under the lip of the brake rod seal to pry it out of the axle casting. Remove the old seal from the rod and clean the rod of any dirt or debris. Put some transhydraulic fluid on the new seal and slide it onto the rod and push it back into the rear axle housing, making sure it seats fully. Reconnect the linkage.
3410 (A47477)
3410 (A47477)
2007 STERLING LT9500 MIXER TRUCK (A58214)
2007 STERLING...
TMA (A55973)
TMA (A55973)
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2021 KENWORTH T680...
