LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,183
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
And every road surface is different, too. My comments were specific for dirt roads and drives because that is what we have here in our part of the country. Very few rural people have paved driveways here - although they are becoming popular closer to town in suburbia. Those surfaces are maintained differently, and our cleated chains would not be appropriatenon asphalt. I do some work on those asphalt & concrete surfaced drives using medium weight FEL tractors, standard industrial flat tread, 4WD, and have no need for chains.
LUCK, rScotty.
I have a 1/4 mile unpaved driveway, it is steep enough that if you put a plow vehicle in neutral with the blade down in 8-10 inches of heavy snow you have to use the brakes all the way down and I have always had to use chains, you would not make it up without studded tires or chains.
I have had and tried numerous sets of chains over the years from double ring and duo-grip to the newer studded types, I have been surprisedan d pleased with the damage that the newer studded ones don't do to the paved roads.
Because of the need for chains my tires are some what unimportant, without chains everything that uses my driveway in thew inter uses studded tires, I have had to let cars down with a chain that made it up with out studs.
