Hedge trimmer for cutting back raspbery bushes?
   / Hedge trimmer for cutting back raspbery bushes? #1
jimainiac
Colebrook, N.H.
Kubota L3830HST
I maintain horse trails in the woods, some of which get overgrown through the summer with raspberry bushes and other plants. I usually walk through, swinging a pruning saw to cut them back.It's hard on the arms and shoulders, so I was wondering how a battery powered hedge trimmer might work. We have a heavy duty gas trimmer that takes a "grass blade", but that's a lot to lug through the woods. We don't have any hedges, so I don't have any experience with hedge trimmers, and I don't know how they would handle this type of work. Has anyone used hedge trimmers in this way?
   / Hedge trimmer for cutting back raspbery bushes? #2
I would think stooping to use a hedge trimmer might take a tool on your body also. Have you considered a "wheeled"trimmer? They can be fitted with string for grass ,weeds and seedlins or saw blade for brush.
   / Hedge trimmer for cutting back raspbery bushes? #3
I have a hedge trimmer,,, a bad back,,, and a FIMCO sprayer,,
Forget trimming,,
hit those raspberries with a little 2-4-D,, and next year there will not be an issue.
   / Hedge trimmer for cutting back raspbery bushes? #4
Forget trimming,,
Or hire a spray plane to do it in a single pass. 2-4-D will kill the trees along with berrys either way. Mis-use of pesticides by misinformed and uninformed consumers is why many are no longer available without permit. If you resort to spray,for goodness' sake use Glyphosate aka Roundup. 2-4-D presist's in soil for months and leaches to be picked up by roots.
   / Hedge trimmer for cutting back raspbery bushes? #5
My F-935 with a 72" deck and Gator type blades does a marvelous job on red and black raspberry plants and grape vines. May take several passes in both directions. Thorns can be hard on the tires, though.
   / Hedge trimmer for cutting back raspbery bushes? #6
I just use a pair of bypass loppers for tougher plants. Of course, depending on the size of the trail and the amount of growth, that could be a lot of work, too.
   / Hedge trimmer for cutting back raspbery bushes? #7
I have used a Ryobi 18v hedge trimmer for years and it works well. If the vine is large, sometimes it will get stuck and you have to dislodge it and go again.
   / Hedge trimmer for cutting back raspbery bushes? #8
Yes, I have and it works good IF you get the right hedge trimmer. The one I use, on youpon infringing on trails, is the EGO 56V hedge trimmer. Last for 60-75 minutes of cutting before it needs recharging and has a 3/4" cut capacity. The weight is 12 pounds. Here is a review that I found to be accurate.
EGO 56V Cordless Hedge Trimmer Review
   / Hedge trimmer for cutting back raspbery bushes? #9
I have one of those. Works pretty good don't it. Also have their 14" chain saw.
   / Hedge trimmer for cutting back raspbery bushes? #10
I used loppers for a few years keeping blackberry , multiflora, and cedar limbs cut back our trail. Wife bought a 22 in Greenworks hedge trimmer for about 100 bucks at wallyworld and its like a Godsend. We ain't kids anymore.
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
