Y'all need to stop posting stuff you made, you're a bad influence on me...3 pt fork/c
   / Y'all need to stop posting stuff you made, you're a bad influence on me...3 pt fork/c #1
davedj1
Jackson, NY
Kubota L2501
Ok so last night I was sitting here searching carryalls, and 3 pt forks.There is some nice stuff built on here for sure :)
A light bulb went 0ff in my head!
I thought, why not have the best of both in one unit.
I already had the forks from my little forklift project and use them to move wood on 1/2 pallets. I will build another set only longer, 40" plus.
I had everything sitting in the shop so today I went to town....
I am going to weld a couple of chain hooks on the bottom of it so I can use it to drag firewood logs with it.
I figure I will use these forks which are about 30" or so long until I get to the steel supplier. I plan on building a carry all of sorts that will be on a pallet or at least on feet so I can back the forks under and I think I'll figure out some way to pin it on for going in the woods or wherever.
I am going to add something to the top, just not sure what yet, I'm thinking a quick attach tool box of sorts, I don't want it on when using the forks but I think it would be handy when the carry all platform is on.
The uprights are 2 1/2 x 2 1/2 x 3/16 wall square tubing as well as the bottom, the piece of angle where the forks sit is a 2" x 2" x 1/4" angle iron, the center piece where the top link hooks on is 1 3/4" x 1 3/4" x 1/8 wall square tube which I still need to add some 45* braces to.
It's about 39" tall and it's 35" wide.
   / Y'all need to stop posting stuff you made, you're a bad influence on me...3 pt fork/c #2
Looks good, but it will work much better with a hydraulic top link. :thumbsup:
You are correct but I don't have any remote hydraulics...yet......and thank you :)
   / Y'all need to stop posting stuff you made, you're a bad influence on me...3 pt fork/c #4
Looks good and great idea. I like the dual purpose ideas. I have been trying to think of some attachment that I coulf use on gy fork lift frame. Remove the forks and attach something else to them. It would save buying or building a few SSQA. A small root digger bucket has crossed my mind.
Again.... great job
Thanks stomper!
I have a bar that goes on my forklift in place of the forks with a 2" trailer ball, great for moving light trailers or my log splitter.
Well my buddy gave me a Reese receiver and I bought a couple of 1/4" hooks for my chokers, got those all welded on today so now it has a couple of more uses :)
   / Y'all need to stop posting stuff you made, you're a bad influence on me...3 pt fork/c #7
Mine also holds a trailer ball, center or offset.
I use the offset one for getting my camping trailer into it's shelter within 2" of the posts; I mount the frame on the FEL and I can look down the side of the wide thing while in the seat.
Handy.
2014 Nissan Pathfinder SUV (A48082)
2014 Nissan...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2013 GMC Sierra 2500HD 4WD Pickup Truck (A50860)
2013 GMC Sierra...
2007 Ingersoll Rand P185 Air Compressor (A50860)
2007 Ingersoll...
2007 GMC Yukon XL SLE SUV (A48082)
2007 GMC Yukon XL...
