First use of ratchet rake
   / First use of ratchet rake #12
Yep...got mine a few weeks ago. Last winter brought down a couple trees (big ones) and a lot of branches. The ratchet rake was a huge help cleaning things up...well worth the investment.
   / First use of ratchet rake #13
I have a problem with snow melting off my garage roof and refreezing on the ground in front of the garage. The RR is great for breaking it up.
   / First use of ratchet rake #14
I really like the idea of the rake on a grapple bucket, do everything with one attachment. Only issue is the loader on my tractor, only rated for just over 1600lbs lift.
I'm not sure of the weight but this is a light weight grapple bucket. It probably don't weigh much more than whatever bucket you have your rake on. The grapple is a 66" bucket with one grapple cylinder. Even a huge pile of brush isn't that heavy, it'll pick up a pile you can't see over. 1600 lb lift on your tractor is plenty for the set up i'm using. My skidsteer will lift more but it's only rated for 2000 lbs.
Large logs and rocks is a different story but for general brush grubbing it's fine. The grapple is a handy tool and one like mine is about $750 - 900. It's a Tomahawk. Cheap built but I've had good luck with it. For what I do couldn't see spending $2000 + for an extreme duty grapple especially since my machine is only rated for 2000 lbs.
   / First use of ratchet rake #15
I have a RR.. somewhere on this site I posted about how quickly it wore out, and posted pics of it. IMO it's good for occasional use but not made with durable enough steel for anything more than that.
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
