2320 Drive Shaft U Joint blew up.
   / 2320 Drive Shaft U Joint blew up. #91
Eeek! (****, as I'm typing I'm realizing this thread is like...5 years old. But anyway...). Hope you figured everything out and were able to get the u-joint and everything fixed by the dealer without to much hassle. And for those of you stumbling across this thread like me - if you have to replace anything I reco ACV. Good stuff, decent prices, good support.
   / 2320 Drive Shaft U Joint blew up. #92
Stumbled across this thread myself. And may others I need to read.
My neighbors 2320, that's probably about 10 years old and 650 hrs, just blew the front joint apart. Won't get a chance to get it to my shop and tear into it til Monday maybe, but what little I see, it looks like the front yoke was toast.
I bout ***** when I saw the $700 pricetag of a whole shaft.
Given the age, it's unlikely dealer will do anything, even with their failure to mention it in the manual, or send the revision to her.
Guess I didn't realize this was a big issue til I started searching. Something like this, I would think, should have warranted a tsb or recall to correct damaged shafts, or to give a first round greasing for free or something to make owners aware?
   / 2320 Drive Shaft U Joint blew up. #93
Does this problem apply to a 2032R or is the 2320 a different design?
   / 2320 Drive Shaft U Joint blew up. #94
The 2320 is the same as the 2025r. I believe the 2720 and 2032 are different but I can not guarantee they don't have a similar issue.
   / 2320 Drive Shaft U Joint blew up. #95
Hopefully it didn't wreck anything on the trans/pump like this one did
http://www.tractorbynet.com/forums/...ating/199396-2320-hydro-drive-shaft-just.html
   / 2320 Drive Shaft U Joint blew up. #96
Didnt seem to. Just the driveshaft. Screwed up the yokes pretty good too. So its gonna cost her $700 instead of $40 with just the joints.
   / 2320 Drive Shaft U Joint blew up. #97
Same thing happened on my 4010, really the same tractor.
The donut thing more or less exploded when I turned the PTO on to the bush hog. Then nothing worked.
I traded it in on the 1025, which proved to be lemon. Than traded that on a 2025, which is near the same as your 2320 and my 4010.
Can't get to that front U joint.
   / 2320 Drive Shaft U Joint blew up. #98
Mine blew today while mowing. My mechanic neighbor came over to show me how to tear it down and make the repair. Looks like parts will be $700. He said it looked like it had never been greased. We had it professionally serviced at 100 and 200 hours. I did the 300 hour service. Nothing in the manual about greasing. Tractor is 9 years old.
   / 2320 Drive Shaft U Joint blew up. #99
If professionally serviced at the dealer, and documented, and you never got the revision about greasing...pressure your dealer for help
   / 2320 Drive Shaft U Joint blew up. #100
Yesterday while servicing my mower I made sure the driveline was greased. Tough to get to but it has to happen.
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
LOT: Welding Power Leads, 220V Electrical Cord (A59076)
LOT: Welding Power...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
