Well, I had the opportunity to play with Jery's fixed forks today. At my dad's house, my brother dropped some dead ash last yr or the year before. Dad and I skidded them out of the woods to cut up for firewood. I wanted the wood as lumber, but we figured the pieces were too knotted to be of any value. He has a JD 1070 with a skidding winch. Tried to skid out 8ft piece, but had difficulty with the rough terrain, nose kept digging into the dirt. Could not get closer then 50ft from the butt. Ended up cutting it into 2 4ft pieces. Worked with a bit of grunt effort on my part. Once out in the clearing, I used Jery's fixed forks and his Tach-N-Go on my
BX2230 to lift the peices off the ground onto some runners. BX had a Kubota weight box with (4) 60lbs sand bags in it. Woodweb.com calculator figured weight as 781 lbs for a 4ft long, 24 inches in diameter for black ash. (not sure how dry pieces were in relation to formula). Tractordata says 950 lbs breakout force, 460 lbs lift to full height at pin. So I think I am happy. Yes the front tires were squished a bit. But didn't travel very far, and ground was fairly level here. Enjoy. Jon <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=507037"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=507038"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=507039"/>
