65 ford 2000 stuck in gear how can i fix
   / 65 ford 2000 stuck in gear how can i fix #1
gregg25
covington,la
ford 2000
i have a 1965 ford 3cyl diesel ,6speed i have swapped top cover as the orig was wore ,
also noticed the square (pawls) that the shift shaft goes into is not perfect its wore .
i hear that i can get a new detent ball and spring and parts ?
does anyone know what part numbers are needed to swap , i tried google but do not know the actual
names of the parts . it works for a week or so then pops out and jams the shifter again and the only cure is more cowbell. i mean poping the top and putting both sticks in neutral and moving the trans forks .
thanks , greg
   / 65 ford 2000 stuck in gear how can i fix #2
i have a 1965 ford 3cyl diesel ,6speed i have swapped top cover as the orig was wore , also noticed the square (pawls) that the shift shaft goes into is not perfect its wore . i hear that i can get a new detent ball and spring and parts ? does anyone know what part numbers are needed to swap , i tried google but do not know the actual names of the parts . it works for a week or so then pops out and jams the shifter again and the only cure is more cowbell. i mean poping the top and putting both sticks in neutral and moving the trans forks . thanks , greg
A lot of Ford Tractor Parts, including yout 1965 Ford 2000, are still available from New Holland delars. This link will take you to one I have used.
New Holland Parts | Buy Online & Save
Enter your model no. In the Model search box and follow the links.
There may be a New Holland dealer near you. Try Google to find one.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 CHEVROLET SILVERADO 1500 (A58214)
2015 CHEVROLET...
JOHN BLUE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN BLUE 1000...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
3PT SUBSOILER (A52708)
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
